Is there a way to disable "CONTROL-S" (Save) Completely?
It's right next to "Control-A" (select all) and danged near "Control-Z" which is "undo"
It doesn't ask if I'm sure I want to save, and I've accidentally overwritten my project too many times now due to my clumsy keystrokes.
I don't want to EVER save via a hotkey.  Undo, yes, Save, no.  Is there a way to disable this?
  • SofaCitizenSofaCitizen Posts: 1,963
    edited July 2022
    • Window > Workspace > Customise (or push F3)
    • In the Actions tab scroll down till you see File and click the + to expand
    • Right-click on "&Save..." & Clear Keyboard Shortcut
    • Click Apply & then Accept
    That should do it.
    Post edited by SofaCitizen on
  • twallingtwalling Posts: 241
    thank you!
  • rosselianirosseliani Posts: 374
    That should do it.
    Thank you for the useful tip!
  • Richard HaseltineRichard Haseltine Posts: 102,792
    You can also remove the Author name, from Edit>Preferences (Daz Studio>Preferences on a Mac) and Save will act like  Save As, always prompting for a name.
    Thank you... that's also a good tip!  I wouldn't mind it so much if it gave an "are you sure?" type of prompt.  I've just had my work overwritten by accidentally saving while trying to undo a few times too many.  I always opt to "Save As" instead of Save, but CTRL-S was just flat-out saving over my work.
  • greywolfgreywolf Posts: 54
    I have discovered, quite by accidexperimentation, that I can use multi-key sequences to trigger most of the menus.  As an EMACS-ish (JOVE) user, I have found it very comforting to be able to bind Ctrl-X Ctrl-C to exit, Ctrl-X Ctrl-S to save, etc.  It lets me expand my surface area of keybindings and lets me move away from the accidental select-all-and-save or undo-and-save, and all that.  Also being able to bind multiple save types to different keystrokes is a boon.  Overall multi-key binding is a God-Send, so whatever you guys at Daz do, PLEASE DO NOT "FIX" THIS!!
    Don't worry http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log_4_12_1_118#4_12_1_63
