G8 male left pupil closed after 4.20 update, how to fix?
SchaakaSchaaka Posts: 147
Wondering if anyone else has encountered this issue before, I tried googling it and nothing came up.
It might be some particular theme of morphs im using that is causing it.
Its only effecting genesis 8 and 8.1 males.
None of the morphs listed in parameters under currently used are causing it nor if I check hidden properties.
I zeroed all them out and still had the same issue.
If I goto edit > figure > zero shape it does fix the pupil being closed.
But as you can imagine I would really really not like to recreate all the morphs of every male character I have.
Im hoping that someone has had this before and has a solution for me,
thanks!
512 x 394 - 209K
  • zombietaggerungzombietaggerung Posts: 3,760
    That was a problem with the Renshaw charcter, but he has been updated for a while. You should uninstall him, redownload and reinstall him however you usually install content.
