Exporting Morphed OBJ's from VWD - How To
Headwax
Hi,
Always had trouble with this. I would try to export a VWD morphed piece of eg cloth and when I bought the OBJ back to Carrara it would be the unmorphed Item.
With 3d Printing etce becoming more affordable I revisited the technique.
So method is as :
1) do VWD sim.
2) Select the VWD object you have just made.
3) go to model room select morphs
4) select frame 1
5) edit
6) then save
it will save it as a car file an dalso saves the mrphed object
Hope this helps someone
yeah I remember having to do that
think adding smoothing also works, been a while since I tried
thanks will try that too - cheers
