Maya 2023 Daz Import Menu Error
![RFB532](https://delorean.daz3d.com/forums/uploads/userpics/773/nLBIU0LDCMEM7.jpg)
In Maya 2023 when I click "Daz Import" on the Maya shelf I get this error. How do I fix it? Thanks
In Script Editor it says:
DazToMaya.run()
# Error: ModuleNotFoundError: file C:\Users\X9Main\Documents\maya\modules\DazToMaya\scripts\d2m.py line 31: No module named 'pymel'
Post edited by RFB532 on
You are almost there. Please look at the last step (step 9) in the installation instructions found here: https://www.daz3d.com/forums/discussion/574846/official-daztomaya-bridge-2022-july-update-what-s-new-and-how-to-use-it/p1
Or watch the video here: https://youtu.be/y1yizEPQvh0?t=136 (around 2:16 time mark)
Thanks for the video time stamped link.
I ticked the box to install Pymell on Maya 2023, but I kept getting the error. I'll review the steps you outlined and the install procedure again to see what I missed.
Thanks for the great work on these Plugins!
@daniel Thanks
The right topic is here. I get this message now:
import sys
sys.dont_write_bytecode = True # don't write PYCs
import maya.cmds as cmds
import DazToMaya
if int(cmds.about(v=True)) > 2020:
import importlib
importlib.reload(DazToMaya)
else:
reload(DazToMaya)
DazToMaya.run()
# pymel.internal.apicache : Rebuilding the API Caches...
modelingToolkit
# Error: OSError: file C:\Program Files\Autodesk\Maya2024\Python\lib\site-packages\pymel\internal\parsers.py line 790: Cannot find maya documentation. Expected to find it at C:\Program Files\Autodesk\Maya2024\docs\Maya2024\en_US
SOLVED - how? IN C:\Program Files\Autodesk\Maya2024\Python\Lib\site-packages\pymel\cache change all 2023 to 2024
Done -_-
Hello. I tried to use Daz2Maya's latest update on Cartoon Adult Female Character, Hair, and Outfit for Genesis 9 and got the following message.
---- Running DAZ Rigger v1.02 ----
// Warning: file: C:/Users/uefi/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 494: New name contains invalid characters. Illegal characters were converted to "_". //
---- Geometries grouped ----
// Error: file: C:/Users/uefi/Documents/maya/modules/DazToMaya/scripts/DAZTools.mel line 1759: setAttr: No object matches name: lForearmTwist_EXP.jointTypeY //
How can I get this to work with this asset? It has worked on Genesis 8.1 females with no issues. Any help is appreciated.
