Couples Poses 09 to 12
A set of 4 couples poses for G8F & G8M.
To install unzip the files and copy the contents of the "My Library" folder to your preferred DAZ Content Library folder.
Once extracted they can be found under People - Genesis 8 - Poses - crp - Couples
Also included are zero and zero full & center poses to zero out the poses and reset position to 0,0,0 for the zero full & center pose.
Usually I add the figures to a group, use the zero & center pose on each so that both figures are aligned and then apply the poses on each.
You may use the content in your commercial or non-commercial renders.
But content may not be re-distributed.
Included in G8F 11 Pose is a pose (G8F 11 Phone.duf) for the Smartphone Prop by Foxclaw used in the promo which can be downloaded here:
https://www.renderosity.com/freestuff/items/87343/smartphone-prop
These are great, thank you!
Hope you get good use out of them as I have from your awesome freebies!
