Huge amount of COMPO files, can I delete???
bryanfbryanf Posts: 23
Hey, I have like 70GB in Carrara compo file extensions dating back a few years, how important are these and can I delete them without the program suffering???
  • 3DAGE3DAGE Posts: 3,311
    Yes,. You can delete any files left behind in your Daz3D / DazTemp folder,.. after crashing or closing Carrara
    If you render out an animation without first giving it a file name and save location,. then Cararra will use the Daz-Temp folder to store the Default animation.
    The Daz Temp folder should be Checked and cleared out regularly,. especially if Carrara crashes.
    Comp files are the Temporary scene files Carrara uses,. If Carrara crashes,. this temp file doesn't get removed,.
    Carrara simply creates a new temporary Comp file for you're new scene.
    Hope it helps
