fatal error Rendering
first of all sorry about my english
fatal error!
Rendering Image
WARNING: QColor::setHsv: HSV parameters out of range
Created RenderCacheBlock
and stop
Please Help
  • Richard HaseltineRichard Haseltine Posts: 102,865
    DAZ Studio, presumably, but what are your render settings? Does a simple primitive (File>New, Create>New Primitive>Accept) render? If so, what is in the scene that won't render?
  • edited December 1969
    my last render.
    900 x 495 - 418K
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Documents and Settings\Public\Documents\My DAZ 3D Library\DAZ 3D\DAZStudio4\dz3delight.dll" at 0033:00000000E8908C36, Dz3DelightDll::DSlo_DetailtoStr()+2318262 byte(s)
    log
    Rendering Image
    edited June 2015
    Do you have the DAZ Studio program installed into your 'My DAZ 3D Library' folder, and is that what you meant to do?
    It is normally stored in Program Files, since it is an application.
    Your scene has at least 7 figures visible in it, have you tried rendering a Primitive cube or something smaller to see if that works?
    What are your system specs, CPU, RAM etc.
    Post edited by JimmyC_2009 on
    edited June 2015
    This is the same problem as
    http://www.daz3d.com/forums/discussion/58479/
    (And there are a couple of others like this floating around)
    The Access_Violation errors are always in the renderer, either Iray or 3Delight and can be with any scene on any hardware...so it is a real bug, not just something in the scene.
    It's also NOT limited to amount of memory used.
    Access_violations are somewhat tricky to track down and may not always be caused by what is showing in the error. The full crash log files are needed to see what's going on...and many times this error can be a permissions related one...or even indicative of bad RAM.
    Please file a support ticket.
    Post edited by mjc1016 on
