How can I zero only one category? (Shaping or Posing)
For example,
when I use the "AB Close Your Eyes! for Genesis 8.1 " in a scene,
I might adjust 10~20 parameters in that category just for one eye,
but if I want to go to the next scene and set that eye back to default,
I have to put zero on every parameters,
it's really inconvenient.
But if I use the "Zero" function from the tab,
all morphs of the head will be set to default.
Is there any way to reset morphs for only one category?
  • PerttiAPerttiA Posts: 10,015
    There is "Zero Shape" and "Zero Pose" in addition to "Zero the figure"
    Expressions should be poses, but not sure where the G8.1 FACS expressions fall into.
    If using the controller that needs to be zeroed too, as I recall, not just the figure.
  • jc3_113jc3_113 Posts: 41
    edited August 2022
    Thanks for the reply!
    But assume I just want to zero only one category,
    like Genesis 8.1 figure --> Head --> Neck,
    and keep other morphs stay the same,
    I can't find a way to do it without putting zero on each parameters manually.
    When I choose "Zero figure shape (pose)" or "Zero selected item shape (pose)",
    the whole head was reset to default.
    Post edited by jc3_113 on
  • It isn't directly possible, but one option is to put the parameters oane in Edit mode (right-click menu), select the properties you want to zero (click frist in group, shift-click last), then right-click>Set>Set Values and enter 0 for the current value (don't edit the default).
    Ya, this works.
    I'm just surprised that I thought this should be a basic function,
    but when I want to do it,
    it's so unhandy.
    But thanks! This helped me to know how to do it.
