Digital Painters Skin Shaders Image Request.
ringo monfortringo monfort Posts: 945
edited July 2015 in Carrara Discussion
Greetings everyone,
I have a special request to ones that have purchase the Genesis 2 females Carrara skin shaders .
The request is to please render some killer looking images using the Genesis 2 Female Skin shaders.
I would like to use some of them as promo images. Image size: 1000 X 1300
The ones that I pick the users get to have the entire Genesis 2 Females skin shader line.
Happy Rendering
Post edited by ringo monfort on
«1
  • ringo monfortringo monfort Posts: 945
    Greetings everyone,
    I would like to use some of them as promo images. Image size: 1000 X 13000
    Happy Rendering
    Ysabeau 6 image.
    1000 x 1300 - 507K
  • MarkIsSleepyMarkIsSleepy Posts: 1,496
    edited July 2015
    ...I would like to use some of them as promo images. Image size: 1000 X 13000...
    Did you mean 1000 x 1300? I assume so, but just double checking... :)
    Also, when you say "Genesis 2 female Carrara skin shaders" do you mean any of the shaders included in this pack: http://www.daz3d.com/dp-ultimate-genesis-2-female-s-carrara-shader-bundle or are you looking for renders of a specific one?
    Post edited by MarkIsSleepy on
    Hi,
    You are correct it should be 1000 X 1300 :)
    Yes any of Genesis 2 female shaders that I have created including the ones in the package you mention.
    Regards
    edited July 2015
    Here's a couple with your Stephanie 6 Carrara shaders. These are straight out of Carrara with no post-work.
    1000 x 1300 - 109K
    1000 x 1300 - 67K
    1000 x 1300 - 37K
    1000 x 1300 - 45K
    Not of a quality to be a promo image, especially with degree of skin coverage, but here is a render of Mei Lin in the world gardens set. Love your products, Ringo.
    1000 x 1300 - 184K
  • 3drendero3drendero Posts: 2,027
    edited July 2015
    Not good enough for a promo, but showing the V6 Carrara shaders in the Ready to Render set Day at the Beach.
    Single HDRI as light. (Tropical beach from http://www.hdrlabs.com/sibl/archive.html )
    Still figuring out Carrara hair on V6...
    1733 x 1300 - 2M
    Post edited by 3drendero on
    And here is the same, but GPU rendered in LuxusCore with OpenCL/Path settings, about 600 samples.
    Same HDRI but as a LuxInfinite light instead, the rest is the same as the Carrara rendered scene.
    1483 x 1163 - 2M
    LuxusCore again, Gamma=3 setting on the HDRI to mach the colors of the Carrara render a little better.
    1344 x 979 - 2M
    Work in progress, this time it is Olympia.
    1733 x 1300 - 2M
    Keep them coming. I would like to have them ready by Weds of next week.
    Thanks everyone!!!
    edited July 2015
    Here's a couple with the DP Olympia 6 shader.
    EDIT TO ADD: The only post-work was compositing in the background - I didn't like the one I rendered originally so I changed them both to a new one. :)
    1000 x 1300 - 104K
    1000 x 1300 - 100K
    Olympia again:
    1040 x 1300 - 369K
    2000 x 1500 - 1M
    edited July 2015
    I have two renders with the Mei Lin 6 shaders queued up that I will post today or tomorrow but I just realized that other than the fun of playing in Carrara and making a bunch of renders I don't know why I spent so much time on this - the possible reward doesn't mean anything to me because I already have almost all of your G2F shaders. :)
    When I go to your store and filter out items I own there's not much left. :)
    1895 x 875 - 136K
    edited July 2015
    Very funny because I am in a similar situation, although the products are different. For example, I like to load the David 5 genesis character, apply Ringo's shader for the David 5 UV set, then zero out the David shape in the parameters tab to return to the default genesis shape, and then reshape genesis to whatever I want, but with the David 5 shader. I bet I am not alone.
    Post edited by Diomede on
    Updated with a Gold shader from another DP shader set, since it is a DP shader promotion and all.
    Still Olympia with the Olympia shaders.
    1040 x 1300 - 384K
    1040 x 1300 - 433K
    1040 x 1300 - 417K
    Two with the Mei Lin 6 Shader.
    1000 x 1300 - 58K
    1000 x 1300 - 95K
  • DustRiderDustRider Posts: 2,766
    edited July 2015
    Here is one from me with your Olympia shaders. Off to work on another one.
    1000 x 1300 - 813K
    Post edited by DustRider on
    edited July 2015
    Here are 2 more, using a freebie scene from Ringo: http://carraracafe.com/news/new-shaders-for-carrara-by-ringo-monfort-dp-monique-6-dp-darius-6/
    One is actually a "failure" but it looked fun with lights instead of gems...
    1000 x 1300 - 584K
    1000 x 1300 - 537K
    1000 x 1300 - 584K
    1000 x 1300 - 537K
    I'm not real happy with this one, but here it is in case it works for you.
  • StezzaStezza Posts: 8,171
    some cracking images being shown here yes
    One more using your Olympia shaders.
    More Olympia 6 and abusing the Caustics functions to the max which turns the red gems into red LED lights:
    Work in progress (<30% done) and time is running out, but here you go, using a DP water shader and a freebie from Most Digital Creations:
    Here's a couple of Monique 6. She, er, brought a friend. (DP Darius 6 of course!)
  • Greetings everyone. I finally managed to get into the new forums. So far the images are looking Grea!
    edited July 2015
    Another one of Monique
    (reattached files)
    1000 x 1300 - 800K
    1000 x 1300 - 580K
    1000 x 1300 - 480K
    Post edited by TangoAlpha on
    Guess that we need an extended dealine since the new forum deletes the attchments...
    1000 x 1300 - 836K
    1000 x 1300 - 682K
    1000 x 1300 - 361K
    1000 x 1300 - 371K
    1000 x 1300 - 384K
    New render, again with a freebie from Most Digital Creations.
    Needs a few tweaks, but since the deadline has passed already...
    1000 x 1300 - 648K
    I see the images from my last two posts went missing - so here they are again..
    1000 x 1300 - 857K
    1000 x 1300 - 846K
  • Excellent images guys! Some of the earliers images that were uploaded prior to the new forum I cannot see them in full size. Some links are broken.
    Thanks to everyone that contributed. I will be contacting you very soon.
    Here is the deal  I just completed DP Ysabeau 6 Carrara Shaders and she will be included in an upcoming release. Here is sample render of her.
    The upcoming release will include all of the Genesis 2 Female Carrara shaders that I have created in a 1 Bundle Package. I will be submitting it to DAZ3D this coming week.
    Hopefully then can schedule its release soon after.
    Regards.
    1000 x 1300 - 528K
    1000 x 524 - 182K
