Interactive Lessons
in New Users
I have downloaded: Interactive Lessons for Daz Studio 4.8+ but am confused on how to use it????? Is there a Help File about these interactive lessons???
Thanks Ron B
If you go to Help > Home > Interactive Lessons, you should get a small bar at the bottom right of the interface which is labelled 'Select A Lesson'
Did you install using DIM (DAZ Install Manager)?
Yes, I used DIM....... It's a great way to get everything in the correct place.
Plus you get all the updates to products which there is a lot of. Manually installing you never know when there is an update.
I think that Daz might consiter making the damn bar a bit more obvious.... Until you referred to it I had never noticed it. Thanks for pointing me in the right direction.
The lessons are there.
