in the moderately close time horizon - mcj_i_k - arms and legs pose helper
mCasualmCasual Posts: 4,607
edited July 2015 in Freebies
the idea is this : you select a hand, run a script, a null node appears at the position of the hand
now, each time someone moves the null node, a mysterious entity ( a callback ) re-poses the arm so that the hand reaches the target
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    oh no it's a tragedy !!! the new forum doesnt accept animated gifs as attachments,
  • StratDragonStratDragon Posts: 3,251
    mCas, you need to stop using "soon" - "Soon" has a bad connotation here and your work turnaround from conception to completion is pretty quick.
    I suggest the following "sooner than soon", "practically in your runtime or "Lickey-split"
    anyway thanks again for cool stuff!
  • LimunLimun Posts: 182
    edited July 2015
    Thank you Casual
    EDIT:
    Btw.i dont see link for download, but i know where to find it..i memorised your site
    Post edited by Limun on
  • SkelchSkelch Posts: 275
    you create such awesome stuff!
    edited July 2015
    so it's somewhat related to mcjAutoLimb and mcjAutoLimb2014
    but it's "live"
    if you know mcjAutoLimb, you know it's for arms and legs only
    ( and can save you hundreds of animation work hours per year, really you need it )
    the "targeter could be a foot, toes, or something parented to a foot
    and it could be a hand, finger or anything parented to a hand, like the point of a sword even!
    mcj_i_k will add pose-solving for trunk nodes!
    example 1, you parent a node to Michael's nose tip,
    using mcj_i_k you'll be able to pull his head by the nose
    the head Joint's Bend control will serve as a length adjustment for the neck-to-nose length
    and the neck joint orientation will serve to "point" the neck-to-nose vector to the target
    example 2, you make Michael's head the "targeter", so you can pull him by the head.
    The neck  Bend control will serve as a length adjustment for the chest-to-head length
    and the chest joint orientation will serve to "point" the chest-to-head vector to the target
    note that this is a pose tool, i dont know yet if i'll add animation features ( or if it can work for that purpose as-is )
    By the way i have a Blog and a deviantart since about July 1st and i plan to add something everyday for years and years
    http://mcasualjacques3d.blogspot.ca/
    here you can see i parented a red ball to Amy/Aiko3's head
    the neck and head joints are used to do the pose-solve
    edited July 2015
    another example
    the red ball is the targeter and is parented to the head
    the neck-bend helps set the chest-to-ball length ( so that it matches the chest-to-target length )
    the chest orientation ( side-side too! ) helps "point" the chest-ball-vector toward  the target
    http://2.bp.blogspot.com/-EoVMPtbPtss/VZ7ozpZwqbI/AAAAAAAABeQ/emvBs33rqEc/s1600/necki.gif
    edited July 2015
    here you can see that the "target" node has a payload
    it remembers which node to bend ( LimbHinge ), in this case the neck
    which node to re-orient ( LimbRoot) , it was the chest, but the user can change it to the abdomen or hip
    and it remembers that the red Sphere ( Targeter ) is the object that it must strive to move to the target location
    in other news i did test it for animation purposes and it works
    i animated the target node
    then i stepped through 30 frames 1 by 1
    the script adjusted the pose for each frame thereby keyframing those poses
    then i deleted the target node
    so i obtained an animation !
    release possibly tomorrow
    possibly being a cleverly elastic promise ! :)
    edited July 2015
    tomorrow, there should be a release = but i think its another forum thread!
    for a change i did something with genesis!
    well AIko5
    but it's not the usual A3
    edited July 2015
    so as i was saying ... today we'll have mcjAimAnim
    which just re-orients a joint to solve an Aim,
    it will work for Pose work
    and it will work for animations
    but the thread for mcjAimAnim is here
    http://www.daz3d.com/forums/discussion/59188/later-today-1-of-2-mcjaimanim-target-targeter-rotator-animate#latest
