i cant move a spear in bryce 7 pro up
hi
i cant move a spear up or around and place it it only moves forward and to the back ground
like it is locked to the ground , did i change something by ax ?
thank you for your time
    select it and check in the object attributes (A) that it is not locked
  • rigomrtsfxrigomrtsfx Posts: 95
    edited July 2015
    hi chohole
    no it still stays locked in place and i have even removed bryce 7 pro and put it back on the computer
    again and i still cant move the spear around the screen , is there away to reset bryce ? i looked and didnt see away
    can you make a screen shot of how to fix the spear if you can , i dont have any screen capture software to take i pic
    thank you from your help
    Post edited by rigomrtsfx on
  • FishtalesFishtales Posts: 6,105
    What viewport are you in? It sounds as if you are in the top down view rather than camera view.
  • HoroHoro Posts: 10,537
    If you're on any Windows system, no screenshot software is needed. Just hit the Print Screen key, open a graphics program, create a new file and paste (ctrl-v)  it. Then save the file.
