Looking for a nametag
in The Commons
Hello,
I am looking for a pin-on nametag similar to the one in the photo. Does anyone know where I can find one?
Thanks in advance for any replies.
nabob21
How close-up does it need to be? If you're only looking at it from far away that seems like something that could be done with a few image files on a flat primative.
I would like to have the ability to do some close-up renders if I can.
https://www.daz3d.com/everyday-labels-and-signs has name tags. All the sets in the "Everyday" sieries are really great within loads of useful props.
ciao
TD
Here... How is this?
Only the Front of the tag is mapped, you'll have to adjust the materials manually for the edges, back, pin and pin housing...
I only had the time to do this in OBJ format.
I didn't check the scale either, but it should load centered and about two scale feet off the floor if it's scaled properly... otherwise adjust as needed and good luck.
That is perfect! Thank you very much McGyver!
You are welcome, I hope it's useful.
Thank you @mcgyver
