Updating shaders for Gen2 which work in Iray
chrbou2001chrbou2001 Posts: 120
edited July 2015 in Product Suggestions
It would be great if we get updated (or new) shaders for wet skin, blood, dirt, wounds for Gen2 which work in Iray. I tried the vein shaders which worked well but the wet shaders didn´t show up in Iray renders. Or at least technical tips how they could work in Iray.
Post edited by chrbou2001 on
  • Richard HaseltineRichard Haseltine Posts: 100,810
    Shaders generally won't work - DS can convert the settings for shaders with standard parameter names. However, I think most of the things you mention are not shaders but materials using standard shaders and those should convert where they use things like layered images to achieve their effect. Where a geometry shell is used, as in some wet-look products, you may need to add a small offset to the shell to avoid issues and may also need to tweak values.
