Convert NLA to Keys?
Dondec
Maybe I missed it somewhere, but Is there any way to convert NLA animation clips to Carrara keys?
I posed a Genesis figure, then later decided to use a G2F instead. I figured out how to mostly transfer the pose using NLA (darnit, I wish the Memorize and Restore Pose feature worked across figure generations). Anyway my pose got converted with NLA, but every time I want to tweak some little thing, I have to enable/disable editing on the Clip.
Thanks in advance
- Don
Post edited by Dondec on
In the NLA Panel,. You should see an option to ( Load Clip Data )
This opens a little panel where you can select any Clip currently loaded in the Scene / Clips area.
Once you select a clip, Carrara will Load the NLA Clip Data into the Sequencer timeline as Key-frames which can then be edited, added to, and saved as a New NLA Clip.
Hope it helps
Thanks 3DAGE ... in plain sight too. Have to laugh.
Thx again
- Don
