DAZ script for erc-bake multipel files
Hello,
I have a bunch of file where I want to remove the erc-freeze.
I figured out that erc-bake is the way to go, but erc-bake is only working for one file at once.
so, I thought maybe a little script could be wirtten do this.
I was thinking about a script that removes from all favourite morphs the erc-freeze.
erc-bake is availibe via the script api.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/ercbake_dz#a_1a0fa552d18aa130c9ad8ac83f17d1f89d
unfortunatelly I have no clue about DAZ scripting.
any hint how I collect all favourite morphs and pass them in a loop to erc-bake?
  • Hurdy3DHurdy3D Posts: 1,052
    edited October 2022
    I made asmall progress:
    var nodeDzNode = Scene.getPrimarySelection();
    var nodeDzObj = nodeDzNode.getObject()
    var modifier = nodeDzObj.getPropertyGroups().findPropertyByLabel( 'Morph name');
    debug(modifier)
    debug(new DzERCBake().getControllerProperty(modifier));
    The main issue is, that getControllerProperty doesn't accept my Property, return is always null:
    Executing Script...
    [object Object]
    null
    Result:
    Script executed in 0 secs 1 msecs.
    Any idea what I have to do here?
    The docu is not pretty helpful here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/ercbake_dz#a_1a0fa552d18aa130c9ad8ac83f17d1f89d
    Post edited by Hurdy3D on
  • I'd add soem error-checking to the script, especially I would break down var modifier = nodeDzObj.getPropertyGroups().findPropertyByLabel( 'Morph name'); into separate steps and check that each strep of the process was giving a valid return.
    Yes, I already checked that one.
    findPropertyByLabel() returns the morph, I tested even reading the current value of the morph.
    However, the thing I don't get is:
    findPropertyByLabel() returns a value from from the type  DzProperty
    getControllerProperty()  expects a DzNumericProperty.
    How can I utlize the result of findPropertyByLabel() for getControllerProperty()  ?
    edited October 2022
    ok I found a solution:
    var modifier = nodeDzObj.getPropertyGroups().findPropertyByLabel( 'Morph Name');
    debug(modifier)
    var bake = new DzERCBake();
    bake.setControllerProperty(modifier);
    bake.doBake();
    I used DzERCBake in a wrong way.
    So... no I have to figure out how to get a list all favourite morphs, any idea?
    edited October 2022
    Someone has to say it: I'm a so [super-duper] S-M-R-T wink
    Found a solution:
    var allProps = nodeDzObj.getPropertyGroups().getAllProperties();
    for (var i = 0; i < allProps.length; i++) {
    var prop = allProps[i];
    if(prop.isFavorite()) {
    bake.setControllerProperty(prop);
    bake.doBake()
    property.getValueChannel();
