Problem with interactive tutorial, How to apply NVIDIA Iray(MDL) material to the skirt
in New Users
As the title requests I don't know how to apply MDL material to the model, I don't see it in the Smart Content pane.
I'm using 4.21 Pro, and the tutorial "Dressing a figure"
Can anyone help?
Where do you see that tutorial?
To apply Iray Uber (MDL) to any surface :
Use the Surface Selection Tool (Alt+Shift+M) and/or select any Surface(s) on your object from the Surfaces Tab.
Then go to your Content Library or Smart Library > Shader Presets > Iray > DAZ Uber > !Iray Uber Base.
or select a surface in the Surfaces Tab. Then go to the sub-tab Presets > Shaders > Iray > !Iray Uber Base.
