Are modifiers limited?
hrpschrd
I am using modifiers to spin objects that are not in the same axis. This works for the first three I did but not the fouth. The fourth object is identical to the third but it seems locked into the axis created for the third. For each object I set the axis of rotation but arranging the object along the x-axis and setting the hot point along the x-axis. This worked for the first three then not the fourth which aligns identically to the third.
Found out! One has to delete/add the modifier after any changes to the hot spot.
Someone can delete this if you wish.
Post edited by hrpschrd on
Nah, keep it...it's good info for future generations
