Morphs for Victoria 7?
I've recently bought the Victoria 7 Pro package, and I am rather lost. Where do I get morphs for the figure, and how do I use them? I skipped genesis and used V4 exclusively until now. The Genesis 3 morphs I bought do not show up in my library.
  • Richard HaseltineRichard Haseltine Posts: 102,865
    The Genesis 3 Female Head and Body Morphs are separate products, Victoria 7 doesn't have her own set of basic shaping morphs.
  • I bought them, but they do not show up ion my product list - just the header, but when I click on them, no icons appear.
    The head and body morphs will not be in your product list. You will find new dials in your shaping tab or property tab when you select the figure.
  • I do not see any new dials in the shaping tab, and I do not see a property tab anywhere, just a "Property Hierarchy" tab.
    I can see these morphs in the Shaping tab.   In Shaping, go to 'All'  with the figure selected, enter a morph you are looking for like 'Height' and you should get about twelve different ones.   That will tell you if they are there and installed correctly.
    If you can't see them there, we will need to look at how and where you installed them.   Did you install with DIM (DAZ Install Manager)?
  • edited July 2015
    I installed them with the Manager. in the "Products" tab their title shows up, but nothing else.I've unsintalled and reinstalled them. But when I start DAZ 4.8 and load Genesis 3 or Victoria 7, nothing but the "Victoria 7" "Navel" and "Mouth Realism HD" dials show up.
    When I check in the Install Manager, it shows up in "Studio3/Content/data/DAZ 3D/Genesis 3/Female Morphs/DAZ 3D/Head" and "Body" respectively.
    Post edited by Starfox_5fe9c4b100 on
    And is Studio3/Content/ set as a DAZ Studio content directory in DAZ Studio? Rob has a script to syn DIM and DS here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/install_manager_config_import/start
  • I have set it up manually under "preferences". It still does not show up as a dial.
    Just to be sure everything is in the right place, could you find the installed morphs' listining Install Manager, click the triangle to the right, Show Installed Files, and take a screen-shot; then in DS go to Edit>Preferences, DAZ Studio>Preferences on Mac, Contnt Library tab, click the Content Directory Manager button, and take a screen shot with the entries under Current expanded to show the paths.
