Simple WorldBalls for DAZ Studio 3/4.5+ and Poser 6+
3dcheapskate3dcheapskate Posts: 2,720
edited December 2017 in Freebies
15 Oct 2016 - Simple manual fixes for reflection/refraction problems in the Poser worldball.
I now have a test version that sets up various NVIDIA Iray render settings and does a couple of otherr things so that the selected environment set will work with Iray - see this 26Nov post
In DS4.8/Iray the worldball sphere blocks the IBL and sun. But simply making the sphere invisible and plugging the environment map into the nVidia render settings environment map gets round that. Of course there's a bit more to it than that (see 11Sep post below), but it seems promising...
Note: The WorldBall was originally created for DAZ Studio 3 and Poser 6, which used biased renderers (3Delight and Firefly respectively). Biased renderers are still an option even with the latest versions of both DAZ Studio and Poser, and the worldball still works fine in DS4.8/3Delight and PoserPro2014/Firefly
(Since the new July 2015 forum software won't let me edit the OP of the original thread I've copied the whole of that post here. That way I can continue to try and keep it up to date. Unfortunately the original links to individual posts on the old thread no longer work - currently they all seem to go to the top of page 5. And the sequential numbering of individual posts on a thread has been removed, so it's not possible to search for the relevant post by its number. Since I don't think that DAZ will ever fix it (I'd love to be proved wrong!) I'm slowly going through this post and manually correcting all the links to the old forum.)
(Full list of environment sets released so far at the bottom of this post)
A free (and probably better!) alternative for Poser if my worldball doesn't suit you - try bagginsbill's Environment Sphere (and for tips on using HDR with it see this "IBL-HDRI" Renderosity thread). And of course with Luxrender (which is what 'Reality' uses) or Iray (DS4.8) you shouldn't be using skyspheres, terraballs, worlddomes, and whatevers at all !
Environment set E20 'Concrete Plaza' released - 20Aug2015 post on this thread
DAZ Studio WorldBall version 2 released - post #2 of this new thread
Poser WorldBall version 5 released - 12th April 2015 post on old thread (original post #121 link)
Simple update for anybody who has BOTH Poser AND DAZ Studio versions, and sometimes loads the wrong prop - 12th April 2015 post on old thread (original post #119 link)
Poser WorldBall Version 4 released - OLD THREAD post 118
Poser worldball bug fixes WIP- OLD THREAD post 113.
DAZ Studio worldball IBL/Sun parenting WIP - OLD THREAD post 114
Poser IBL/Sun parenting workaround in OLD THREAD post #105.
Preview icons to remind you what the environment sets look like - OLD THREAD post 98/99
Helper scripts for creating your own sets - OLD THREAD post 97
Caution on using UE2 instead of the WorldBall IBL - OLD THREAD post #96
Tentative first steps into using HDR lighting with the WorldBall start at OLD THREAD post #88. First environment set to include HDR lighting (as well as normal lighting, not instead of!) is E18 Alien Desert (OLD THREAD post #94).
The WorldBall was created as a quick-and-easy way to add a simple background to a scene without having to hunt through libraries, or worry about backdrop positioning, lighting, and camera angles. It's far from perfect, and way behind the more professional environments and skydomes, but it's good enough for the intended purpose and has it's own upstart charm! ;o) Check out some of the results at the Poser/DAZ Studio WorldBall Render Gallery thread over in the DAZ Art Studio forum (and feel free to post your own there too!)
The Simple WorldBall is available in both Poser and DAZ Studio versions. It consists of an all-encompassing sphere with a full 360° azimuth / ±90° elevation background image, a light for global illumination, another light to create the sun shadows, and a ground plane used as a shadowcatcher. There are five very simple envirponment sets included (plus one test environment).
There's a single script file to load/change the WorldBall - simply double-click the script icon. It prompts you to select from the available environment sets, and then loads the WorldBall, IBL, Sun (and Ground) with the appropriate settings. Use the same script to change the environment after you've loaded the WorldBall.
The environment data is contained in a plain text file so you can easily add additional environments.
Simple Poser WorldBall
The original Poser version is available at ShareCG or Renderosity Freestuff) (Note: The original Poser WorldBall didn't work on a MAC - Version 2 upload fixed this. Version 3 fixes the irritating 'please locate WorldBall.lt2 issue. Version 4 fixes the background not displaying in preview and possibly the light colour/intensity not updating. Version 5 parents the sun and asks if you want to use IDL if your Poser version supports it.)
The WorldBall is a Poser prop, the IBL is a Diffuse IBL light, and the sun is a distant light. The default GROUND prop is used.
The PoserPython script file is in plain text, so if you're a code-monkey feel free to play with it. It's still at the 'held together with sticky-tape and string' stage - but hey, it works! ;o)
Feedback regarding any problems you encounter would be appreciated (as would suggestions for improvements, additional environment sets, etc)
Simple DAZ Studio WorldBall
Available at ShareCG or Renderosity. (Version 2 fixes a few bugs, you can finally see the background in the preview, and sun/IBL are parented to the worldball)
(Note: The WorldBall works on DS3 and DS4.5 onwards, but NOT on the intermediate DS4.0 - I' tried, but failed, to resolve this.)
IMPORTANT! SEE THE README FOR INSTALLATION DETAILS - THE SHADERBUILDER IBL MUST GO IN A VERY SPECIFIC LOCATION. There were a couple of errors in the original ReadMe (fixed in the Version 2 upload):
1) it should tell you to copy the CONTENTS of the 'Studio3/4 ShaderBuilder Light' folder, NOT the folder itself! See OLD THREAD post #6)
2) You need to copy the appropriate 'Studio3/4 ShaderBuilder Light' if you use DAZ Studio, REGARDLESS of whether you use Poser.
The WorldBall is a Poser prop, the Ground is a DS plane primitive with a ShaderMixer material, the IBL is a ShaderBuilder light, and the sun is a simple distant light.
The DAZ Script file is in plain text, so if you're a code-monkey feel free to play with it. It's still at the 'held together with sticky-tape and string' stage - but hey, it works! ;o)
Hints On Using The WorldBall
- Do Your Figures Look Too Dark In Your DAZ Studio WorldBall Renders? OLD THREAD post #6
- Adding Your Own Environment Sets - The ‘WorldBallData.txt’ File OLD THREAD post #7
- A Few Tips For Adjusting The Lighting And Shadows OLD THREAD post #13
- If you want AO from the global illumination in DAZ Studio, try using the UberEnvironment2 (free with DS3A and DS4 Pro) instead of the WorldBall IBL - OLD THREAD post #25
- A couple more hints on how I use the WorldBall - OLD THREAD post #68
Full List Of Environment Sets Released To Date
(All environment sets are available from ShareCG and Renderosity Freestuff. Links to post numbers are to posts later in this thread)
E00 'Test1' - included with both the Poser and DAZ Studio verisions of the WorldBall
E01-E05 'Snow/Lake/Sand/Scrub/Mars' - included with both the Poser and DAZ Studio verisions of the WorldBall
E06 'Mountain Lake 01' -OLD THREAD post #15,OLD THREAD post #31 - ShareCG / Renderosity Freestuff
E07 'Above The Clouds' -OLD THREAD post #15 - ShareCG / Renderosity Freestuff
E08 'Below The Waves' -OLD THREAD post #15 - ShareCG / Renderosity Freestuff
E09 'Swimming Pool' -OLD THREAD post #26 - ShareCG / Renderosity Freestuff
E10 'Northern Forest' - ShareCG / Renderosity Freestuff
E11 'Misty Mountain' x 4 (the same scene in dawn, noon, evening and moonrise variants) -OLD THREAD post #34 - ShareCG / Renderosity Freestuff
E12 'Basic Toon' x 4 (the same scene in dawn, noon, sunset and midnight variants) -OLD THREAD post #42 - ShareCG / Renderosity Freestuff
E13 'Earth Environs' x 2 (a low earth orbit scene with earth, sun, moon, and stars plus a starfield only variant) -OLD THREAD post #58 - ShareCG / Renderosity Freestuff
E14 'Grasslands' x 2 (the same scene in daytime and evening variants) -OLD THREAD post #60 - ShareCG / Renderosity Freestuff
E15 'Galaxies And Nebulae' (14 galactic/nebulous Hubble images strewn unrealistically across an Earth-based starfield!) -OLD THREAD post #66 - ShareCG / Renderosity Freestuff
E16 'Cinderside' (volcanic ash over lava) -OLD THREAD post #67 - ShareCG / Renderosity FreeStuff
E17 'Danny's Island' a tropical paradise, with a lurking shark! -OLD THREAD post #92 - ShareCG / Renderosity FreeStuff
E18 'Alien Desert' (lo-res background, but includes HDR lighting for Poser/DAZ Studio) -OLD THREAD post #94 - ShareCG / Renderosity FreeStuff
E19 'Sea Dawn' -OLD THREAD post #100 - ShareCG / Renderosity Freestuff (soon)
E20 'Concrete Plaza' (double resolution 8192x4096 background) - 20Aug2015 post - ShareCG / Renderosity FreeStuff
E21 'Above The City' ( double resolution 8192x4096 background) - 24Aug2015 post - ShareCG / Renderosity FreeStuff
(I also have the original cubemap renders and vertical cross images - if anybody prefers those please contact me)
If you can't see what you're looking for in that list, I take requests, or you could...
Create Your Own 360° Azimuth / ±90° Elevation Backgrounds
Using just Terragen Classic, GIMP, and HDRShop Version 1 (all free) it's far simpler than you'd imagine! Check the "Make Your Own Environment Maps And Light Probes" PDF at ShareCG (also at Renderosity > Tutorials > Other Software).
If you picked up Bryce 7.1 Pro when it was free, then it provides a marvellous alternative to Terragen Classic. Just remember to set the render FOV to 112.5° !!! (You need to do this in order to get a 90° FOV render - for some arcane reason Bryce uses 80% of the FOV you type...) And don't forget to UNCHECK'Link Sun To View'.
Edit 31st Jan 2014: I've uploaded a couple of helper scripts to automate the two most tedious and error-prone parts of the procedure - see OLD THREAD post 97.
Post edited by 3dcheapskate on
«1
  • 3dcheapskate3dcheapskate Posts: 2,720
    edited July 2015
    DAZ Studio WorldBall Version 2 (Updated Files ONLY) Released
    Version 2 of the DAZ Studio WorldBall finally fixes a couple of rather irritating problems:
    • automatically parents the WorldBall Sun and IBL to the WorldBall.
    • you now see the background in the preview pane.
    Download links:
    ShareCG: Ver 2 [UPDATE ONLY] Simple DAZ Studio WorldBall
    Renderosity: Ver 2 [UPDATE ONLY] Simple DAZ Studio WorldBall
  • atticanneatticanne Posts: 3,009
    Thank you, Pete.  Now to find time to play again.
    edited September 2015
    In these modern days with LuxRender/Octane/Cycles, and with DS4.8 and its nVidia renderer this li'l' ol' worl'ball is rather behind the times. But I like it, and it seems that a few other folks do too. So I've started looking at a couple more minor changes (improvements perhaps? ;o) ) to the DAZ Studio version. Something to make the shadowcatcher groundplane more sensible in the preview pane (millighost and mjc1016 have shown me how to get the basics working for DS4, but still no luck with DS3), and adding AO to the WorldBall IBL (no luck there so far, although I think I'm on the right path. Maybe).
    I've recently opened up the ShaderBuilder light again and started playing with it - mainly trying to work out how an occlusion brick would be connected up. The lack of documentation reminds me of the fun I had creating it originally! Also I've realized that a little bit of explanation of the IBL in the DAZ Studio WorldBall may be useful.
    Firstly, I've recently taken to calling it a 'faked 'IBL. It's basically a ShaderBuilder point light (i.e. a light that radiates outward from that point in all directions). But I did a bit of lateral thinking (with some assistance from others) and positioned the light at the end of the surface normal. If that doesn't mean anything think of it this way - at any point on any surface in the scene this light is a fixed distance out along the perpendicular from the surface. The surface normal is also used to pick the correct point on the light image map. The result of this is that this IBL light shader simply 'projects' the IBL image map onto everything in the scene. Adding some 'blur' to the image map prevents it just looking like a reflection. I've attached a couple of screenshots to show this (worldball with scrub set, two sphere primitives and one plane primitive,sun disabled). The default blur is 0.3. A value of 0.0 looks like a reflection*. A value of 1.0 looks like a fixed colour everywhere. I think values between 0.2 and 0.7 probably work best.
    Another thing I noticed (again) is that there's a tiny white spot in the middle of each sphere. I think this is unintentional specularity from the IBL (the surface normal at those points is pointing directly into the camera). I still don't know how to fix it.
    *but it isn't - for a reflection ReflectedAngle = IncidentAngle, but here the light you see (from any viewpoint) at any point on any surface always has a 90° IncidentAngle (or is that a 0° IncidentAngle? I can't remember whether incident angle is measured relative to the surface or to the perpendicular... )
    655 x 921 - 159K
    edited August 2015
    Concrete Plaza WorldBall Environment Set (E20)
    First one for a long time.
    Downloads available from the usual places...
    ShareCG: Concrete Plaza WorldBall Environment Set E20
    Renderosity: Concrete Plaza WorldBall Environment Set E20
    This set is basically a test of my new procedure for creating higher resolution backgrounds in Terragen, and using Poser to incorporate props like buildings and trees ( http://www.sharecg.com/v/81918/view/8/Script/26FaceWB  ).
    I think I had the incorrect render settings in Terragen Classic, resulting in colour banding in the sky. I do intend to fix this... sometime...  :D The colour banding is in the sky of every environment set I've done - I'm fairly sure it's just the old CG colour banding issue.
    You'll also notice (look at the shadows in the render, bottom right of promo image) that the buildings appear to be a miniature model futuristic city - either that or the characters are giants. Scaling the buildings down seemed a good idea when I created this set, but that was something I didn't foresee. Like I said, this set was mainly a test for my procedure. I'm doing a bit more playing to try and get this more realistic...
    N.B. Several of the free Dystopia City Blocks 001-010 and 011-020 were used to create this.
    I requested and received the creators' permission to distribute this derivative work.
    Big thank you to 'billy home'.
    800 x 800 - 159K
    edited August 2015
    Above The City WorldBall Environment Set (E21)
    ShareCG: E21 Above The City Worldball Environment Set
    Renderosity: E21 Above The City Worldball Environment Set
    This is another test of the Poser part of my new procedure for incorporating props like buildings and trees into backgrounds( http://www.sharecg.com/v/81918/view/8/Script/26FaceWB  ).
    Fairly obviously this set works best for aerial scenes, or looking out from a high-rise balcony/window. And you'll probably want to adjust the default light intensities, maybe 60-75% for both? I think the default 50% that I've set is a bit low.
    Once again several of the free Dystopia City Blocks 001-010 and Dystopia City Blocks 011-020 were used to create this. Rather than leaving the blocks at their default 100% scale when I created the scene in Poser (as with E20), I increased it to 5000%. This made the city blocks look about right if I had figures in the scene too. I also added a city block at the centre (instead of leaving an open 'plaza') and raised the camera to be in the air above it (instead of 6' off the ground as in E20).
    800 x 800 - 204K
  • sueyasueya Posts: 832
    Please can you clarify where the data file goes. I installed as per the instructions and Daz studio is still complaining that it can't find the data file.
    Sure thing. It needs to go either (if you only use DAZ Studio) in one of your mapped DAZ Studio content directories, or (if you use just Poser, or if you use both Poser and DAZ Studio) in one of your mapped Poser runtimes. The actual path will be one of the following:
    {mapped DAZ Studio content directory}/Scripts/3DCheapskate/WorldBall/WorldBallData.txt
    {mapped Poser runtime}/Python/poserScripts/3DCheapskate/WorldBall/WorldBallData.txt
    If you're uncertain about what directories/runtimes you have mapped in DAZ Studio, from the menu bar select Edit > Preferences > Content Library > Content Directory Manager and expand "Daz Studio Formats" and "Poser Formats" (see first screenshot below - note, this is from DAZ Studio 4.6 but 4.8 should be the same. {edit: Also note that you'll probably only have one or two entries - my setup is unusual} )
    You can double check exactly where the "WorldBall Setup DS3,4" script looks by attempting to load the worldball and then from the DS menu bar selecting Help > *TroubleShooting > View Log File (see second screenshot below - note, this is from DAZ Studio 4.6 but 4.8 should be the same...)
    When the logfile is displayed scroll to the very bottom. You should see something similar to the third screenshot below (for a normal setup it should only find one datafile) - the lines highlighted in yellow are the full pathname/filename/extension that the script checked. {edit: they should correspond to the mapped DAZ Studio content directories and Poser runtimes that you found when you looked in your preferences}
    If you still have any problems let me know.
    *P.S. The popup that appears when it can't find the datafile was correct for DAZ Studio 3 (Help > View Log File). In DAZ Studio 4 they added the extra "Troubleshooting" step (Help > Troubleshooting > View Log File). I should really correct that in the next DS worldball update ...
  • Oso3DOso3D Posts: 15,040
    Is there any easy way to access just the images? I can't for the life of me figure out how to make the worldball work at all, and since I use Iray I'm not sure it'd do much anyway, but I could use the images to make something similar to the worldball on my own.
    (I've been making a sphere with a 180 degree spotlight where the sun should be)
    edited November 2015
    If you just want the background image and/or reflection map (which is just a mirror image reduced resolution version of the background image) they're in the following subfolders. There are 7 JPGs in each of those two folders in the main DSworldball zip - two test environments plus five different variants of the same terrain, i.e. snow, lake, sand, scrub and mars:
    • DS Content\Runtime\Textures\3DCheapskate\EnvironmentMaps\
    • DS Content\Runtime\Textures\3DCheapskate\ReflectionMaps\
    Note: the DS version of the worldball doesn't need the angular map (lightprobe) mapping - if you want those you'll need to download the Poser version of the worldball, or convert them yourself.Here's the path:
    • DS Content\Runtime\Textures\3DCheapskate\LightProbes\
    With all the other environment sets all three images (environment, reflection, and lightprobe) are provided, and the readme gives you all the necessary info. The images are in the same folders as above.
    Regarding your not being able to get the worldball to work at all, the latest version of DS I have installed is 4.6 - so it's possible that there may be problems I don't know about in DS4.8 which is what I assume you're using (I had a similar problem back with DS4.0). Also check my response to nakamuram's question about 3Delight/nVidia renderer on the Renderosity worldball thread here https://www.renderosity.com/mod/forumpro/?thread_id=2867793&page_number=2#msg4218570
    Also bear in mind that version 2 of the DS worldball was released as an "Update Only" variant which require the earlier full release of version 1 to be already installed. If you've inadvertantly just downloaded the update it won't work.
    I'm more than happy to try and help if you want to try and resolve the problems. I'm also more than happy for you to just use the images if you want.
    But you've raised a good question...
    *** Is anybody using the DS worldball successfully with DS4.8 ? ***
    *** With 3Delight? With the nVidia renderer? With both? With neither? ***
    Question answered - skyspheres, terraballs, worlddomes, environmentboxes and whatevers will not work in PBRs (physically based renderers) because they are a specific workaround designed for biased renderers - opaque, visble, all-enclosing objects that cast no shadows and have no effect on the light that passes through them.
    It's easier to simply do my own 'worldball' in DS 4.8, so it's all good.
    (Sphere, add texture to diffuse and emission, place spotlight where sun is, angle it, then parent it all to a zero hinge, and scale it up)
    I've been converting a bunch of old skydomes this way.
    Whatever keeps you happy !  When I created this there were many skyballs, terraboxes, worlddomes, etc, available already, but I just wanted to do one for myself. So I know the feeling. :)
    (maybe an infinite/distant light, rather than a spot, is more appropriate for the sun?)
    Distant light is blocked by skydomes in Iray unless you lop off the top or something weird.
    Missing Preview Thumbnails For E20 And E21
    Edit: Missing files uploaded to ShareCG as "Missing E20,E21 WorldBall Preview Thumbnails"
    Just realized that I forgot to include preview thumbnails with the last two environment sets (E20 and E21). A PP2 and a PNG for each set, so four files in total.
    • E20_ConcretePlaza.pp2
    • E21_AboveTheCity.pp2
    All four should go in the same folder as all the other previews, which will be one of these:
    • {The DS Content DirectoryWhere You Put The WorldBall}\Runtime\Libraries\Props\3DCheapskate\WorldBall\!Previews\
    • {The Poser Runtime Where You Put The WorldBall}\Libraries\Props\3DCheapskate\WorldBall\!Previews\
    The two PNG files are attached. The E20_ConcretePlaza.pp2 and E21_AboveTheCity.pp2 files should be exactly the same as all the other preview PP2 files, i.e.
    version
        number 5.0
        // just a thumbnail place holder file
    You'll have to create those yourself, or download from ShareCG (link at top of this post)
    91 x 91 - 11K
    91 x 91 - 17K
    Ah, of course - Iray's a physically based renderer so you won't have an option to turn off shadowcasting for the sphere.... so my li'l' ole worldball wouldn't work - the ball would be blocking the sun. I've added a note to the OP and thread title.
    I recall in the DS/Poser > Reality > Luxrender route you could dispense with the sphere completely and plug the environment map directly into a GI lighting and/or backdrop 'channel' (not sure of the terminology) - can't recall whether the GI and backdrop were separate, or a single 'channel'?).
    I'd guess that Iray has something similar?
    Maybe it's time for me to update my installation (currently DS3 32/64bit, DS4.5 32bit, DS4.6 64bit). Don't think many people will still be using DS4.5, so maybe go for DS4.6 32 bit and DS4.8 64 bit - I even have an nVidia GeForce GT525M (but not sure that'll be recent enough to use Iray?)
    You have environment map, which works great. But then you have to place a spotlight carefully to align with the backdrop.
    Possible Simple Workaround To Use Worldball In Iray
    Just installed DS4.8, and using the worldball in an Iray render (CPU, as I can't get it to use my GPU) I get a completely black render.
    But simply making the worldball invisible allows both lights to work correctly (I checked the IBL and sun individually and they both work fine)
    And if I then (in the nVidia render settings) plug the environment map (the one that's plugged into the worldball) into Environment Map, set Environment Mode = Dome And Scene, set Dome Mode = Infinite Sphere, and set Draw Dome = On ... well... see the screenshot.
    Needs some tweaking of levels obviously, but it should be fairly simple to automatically do all that in the script (provided DAZ Script gives access to those render settings). And obviously it needs a bit more looking at - I only spent a couple of minutes looking at it so far...
    (just goes to show that you should always double/triple-check things for yourself !  ;o) )
    Edit: Notes for things to check...
    Sun and IBL should be automatically be correctly aligned, provided the Iray environment map is aligned the same way as the worldball. If not it should be a simple azimuth offset, and since the sun/IBL will still rotate with the worldball sphere that should be easy.
    Shadowcatcher groundplane not working (no real surprise... in PBR terms a shadowcatcher makes as much sense as an opaque sphere that doesn't cast shadows! ;o) )
    1176 x 639 - 181K
    That's interesting, I'll try that.
    I've had a PM that somebody is getting the following error when they try to run the DS worldball:
    15 var g_oFILE = new DzFile( getScriptFileName() );
    error in line 15
    I'm puzzled by this one, since it doesn't happen on my system, and yet it seems to indicate a DAZ Script parsing error on the very first line of code. So has anybody else seen this ?
    (I'm guessing that when you run the worldball script nothing seems to happen, and you have to go Help > Troubleshooting > View Log File and scroll to the bottom to see the error message)
    ~ ~ ~ edit ~ ~ ~
    I've just noticed that the EOL characters in the .DSA file are inconsistent - some lines have just LF, others have CRLF (see attached screenshot of the DS worldball version 1a script). This doesn't seem to cause any problem on a Windows system, but might cause a problem on a MAC... ? (I don't have access to a MAC so can'tcheck)
    926 x 163 - 57K
    It's ok I managed to get the Worldball to work in the end as you can see from this render.
    963 x 550 - 332K
    578 x 330 - 73K
    Post edited by sueya on
    Glad you got it working - sorry about the problems. (by the way - your image attachment didn't upload... one of the many ongoing DAZ forum problems - image attachment uploads often fail)
    I'm still interested in details of any problems anybody has - that way I can fix them. Please post problems in this thread, or PM me - I'm happy with either way.
    I managed to upload a smaller copy of the image as you can see from the post above.
  • MjvolMjvol Posts: 93
    Hello there 3dcheapskate I like the name. Anyway just want to say , I am a fan of you Materials,  love your skydome, they don't work for me, only because I lack the knowledge to use them. But they sure look nice and so does your other stuff. I just wanted to say keep the good work. Take care
    Mjvol
    Mjvol
    Thanks for the compliment (first time, I think, that somebody who can't use my stuff says they like it! LOL) - and I like the name too!  :D (the 'cheapskate' bit is because I have a very limited budget, and need to really watch the pennies for non-essential hobby-related stuff)
    One of the main aims with all the stuff I've uploaded was to make it easy to use, so if you're having problems trying to use anything I've made, then I probably need to improve the instructions !
    P.S. If there's anything specific you want to get working, you're welcome to PM me - I'm happy to try and help you get it working step by step. :)
    Test Version Of DAZ Studio WorldBall Script With Added NVIDIA Iray Setup
    I've got a new test version of the DAZ Studio Worldball script that sets things up more-or-less correctly for the NVIDIA Iray renderer. If anybody's interested in having a play with it I can upload it to ShareCG. I might do that even if nobody's interested... ;o)
    One double-click to run the script, plus six clicks on various dialogs is all it took to setup/switch between the environment sets for the attached NVIDIA Iray renders.
    There's quite a few things still not right - if you look at the attached renders 45.jpg you'll notice I'm using the wrong dome mode ! blush
    600 x 282 - 20K
    400 x 271 - 18K
  • MilosGulanMilosGulan Posts: 1,966
    Sure I am interested :) not yet into Iray but might be hopefully.
    Definitely interested.
  • That's two more responses than I expected !  laugh
    Just off to package this up for upload...
    Almost ready. Here's a couple of screenshots running the test script in DS4.8 (attached images are in the wrong order because I didn't spot that one initially failed to upload)
    1 - the initial dialog is a health warning, indicating that this is a test script !
    2 - the environment set selection dialog now has an extra drop-down for renderer (if your DS version has multiple renderers - you won't see anything different if you're using DS3). By default the NVIDIA Iray is selected. The other options (on my system) are "3Delight" and "Scripted 3Delight", but they don't do anything - if you select either of those the WorldBall will be set up in the original way.
    3 - you should get a confirmation dialog telling you that the environment set has been successfully set up (if you don't then the script has probably *crashed !) - your Iray renders should now use the selected worldball environment set for lighting and background. If you look at the Iray render settings the ones outlined in orange are the main ones the script has set up. If you look at the Scene pane you should see the Worldball, Sun, IBL and Ground loaded, but only the WorldBall Sun (a standard DAZ Distant Light) will be visible. The Worldball node should be automatically expanded so you can see the IBL and Sun, but there appears to be a bug in DS4 preventing this from happening.
    A few additional notes to follow once I've uploaded...
    *If you do get a crash look at Help > Troubleshooting > View Log File and scroll to the bottom to see debug for the crash.  I haven't seen any recently, but then I've been mainly repeating the same sequence. If it crashes on you then please let me know the details so I can try and fix it!
    960 x 377 - 98K
    818 x 582 - 112K
    570 x 465 - 50K
  • Test Version Of DS WorldBall With Iray Setup Available At ShareCG
    Okay, it's uploaded - please see the previous post for some background information.
    TEST version of DS WorldBall with Iray setup - http://www.sharecg.com/v/82884/view/21/DAZ-Studio/TEST-version-of-DS-WorldBall-with-Iray-setup
    This is a TEST version (2.04) of the WorldBall that adds setup for Iray.
    It is provided as-is for anybody who wants to test it.
    I have done some basic checks and it appears to work correctly.
    However, the code is written in my usual haphazard style, and there are almost certainly bugs in it.
    THEREFORE USE OF THIS SCRIPT IS AT YOUR OWN RISK ! :)
    If you wish to cancel this script you can do so in the next (or next-but-one) dialog.
    There are only two files:
    IrayTEST2-04 WorldBall Setup DS3,4.dsa   ...the modified script with Iray setup for testing
    IrayTEST2-04 WorldBall Setup DS3,4.pp2   ...a renamed copy of the most recent official release of "WorldBall Setup DS3,4.pp2"
    They are both in an "IrayTEST" subfolder in the normal Worldball Poser runtime location (so they won't overwrite your existing worldball, which you can continue using as normal)
    You need to have the latest version of the DS worldball already installed.
    You can then simply copy the two files to the correct subfolder (the default folder structure is already in the zip)
    If you have any problems, crashes, questions, suggestions, etc related to this thens please post here or contact me via any of the usual channels.
    I may be away from the internet from sometime mid-weekend till midweek
    A couple of further thoughts/comments/observations:
    - I'm not sure what will happen if you have Reality installed. It should just appear as an option on the renderer dropdown, but if you select it then the worldball should just be set up in the original manner.
    - To see the backdrop in the preview pane simply make the WorldBall visible in the Scene pane. But remember to make it invisible again before rendering or you'll get a total blackout render (unless the camera's outside the worldball prop)
    - You probably want to load a camera and set it to 35mm to see a reasonable section of background
    - The WorldBall prop is very small and centred at the world origin, so if you move the camera you won't be viewing it from the centre of the ball. With the Iray infinite sphere the camera view should always be from the centre of the sphere. Therefore unless your viewpoint is at the world origin you'll probably see a mismatch between the Worldball prop (if you make it visible) and your Iray render.
    - I should of course be setting dome mode to "Infinite Sphere" and NOT "Infinite Sphere w/ Ground" ! You'll have to do this manually for now.
    - If you're a proper programmer (as opposed to a code monkey) remember to put on your peril-sensitive sunglasses before looking at the code ! cheeky
    A couple of known bugs:
    - The WorldBall node is collapsed in the Scene pane when you first run the script after opening DS. This may be a DS4 bug as noted in an earlier post.
    - I'm using the wrong dome mode - it should of course be "Infinite Sphere" and NOT "Infinite Sphere w/ Ground" !
    - Regardless of the renderer you select I think it sets NVIDIA Iray!
    And another point - the main purpose of the worldball was twofold:
    1) to allow me to easily change the lighting and backdrop by selecting from a list of available environment sets.
    2) to let me easily add environment sets to the list.
    I'm more than happy that it's met both those goals.
