mcjFrameMaker: Jan 4 2023 Upg Frame Your renders as Stills, later as Slideshows
mCasualmCasual Posts: 4,607
edited January 2023 in Freebies
Jan 4 2023 UPDATE
mcjFrameMaker_2023_01_04
That's the version i've been using and improving in recent weeks
example:
November 9th 2022 19:38 -Upgrade:
[Add All Images in Folder] button
Easier selection of mixed image files  extensions
*** THE LINK ***
https://sites.google.com/site/mcasualsdazscripts10/mcjframemaker
I wrote a Daz script that converts a collection of images (in a folder) into a Slideshow Video with the help of FFMPEG.
That script named mcjSlideShowVideoMaker will be posted later. WAS POSTED
mcjSlideShowVideoMaker accepts frame/layouts, but the frame/layouts have to follow a standard that I developed ... so ...
https://sites.google.com/site/mcasualsdazscripts10/mcjslideshowvideomaker
https://www.daz3d.com/forums/discussion/602101/mcjslideshowvideomaker-present-your-renders-as-multi-cells-videos-fast-critical-update-%E2%80%8Enov%E2%80%8E-9
... so ... I wrote mcjFrameMaker which lets you create those standard  frame-layouts.
Then I added the option of mounting images right in mcjFrameMaker.
364 x 364 - 135K
1080 x 584 - 296K
1080 x 607 - 1M
3840 x 2160 - 4M
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited October 2022
    Output From The Making-of mcjFrameMaker
    1920 x 1080 - 2M
    edited October 2022
    1920 x 1080 - 258K
    edited October 2022
    Output From The Making-of mcjFrameMaker ( actually from mcjSlideshowVideoMaker )
    1440 x 2560 - 5M
    edited October 2022
    mcjFrameMaker: is ONLINE ! Quickly Frame Your renders
    Free Script For Daz Users
    364 x 364 - 135K
  • TugpsxTugpsx Posts: 747
    Awesome thanks for sharing. This turned out great.
    Tugpsx said:
    Awesome thanks for sharing. This turned out great.i
    if i did it correctly, on the first run, you click the [Create Frame] button and bam you got a frame
    edited October 2022
    Attention
    Oct 29th evening ( the first version ) had a strange bug wherein the dimension of the background image was de-centering the Bottom and Top Texts of the frames
    Oct 30th morning's version solved this by using the image.smoothScale() function instead of the image.Scale() function. Also, I repaired the [clear image list] functionality
    here's an example of the before/after debugging.
    It's as if the image.drawText function was working according to the metrics of the loaded images even if it was presented with the resized image.
    maybe the imageManager was involved in the issue
    1920 x 1920 - 524K
    1920 x 1920 - 449K
    Thanks for the update
    edited October 2022
    next i'll adjust mcjSlideshowVideoMaker to accept the frame-layouts generated by mcjFrameMaker
    it uses ffmpeg, but one issue is that it seems to load each image of the slideshow in RAM
    then overlays them to make the crossfading effect, I recently saw that we have scripting-access to the video-encoder used by daz studio.
    but it's .avi-only and I prefer ffmpeg with its large set of mp4 codecs. maybe the best would be to generate the 2500 images of a 100 seconds slideshow
    in Daz Studio, which can mix 2 images for the crossfading segments, and feed them one by one to ffmpeg through some "stream" input
    edited November 2022
    My Free Daz Studio Script mcjSlideshowVideoMaker has been released !
    It lets you quickly create videos like this one in matters of minutes.
    https://www.youtube.com/watch?v=ztkS1J3D7kY&ab_channel=mcasual
    it can use the Frame-Layouts you created with mcjFrameMaker
    ( in fact it's the reason I created mcjFrameMaker )
    3840 x 2160 - 5M
    Very cool. Thanks this will be great for making videos of our artwork collection or as you have shown when coupled with AI generators to produce music videos. Very cool.
    Upgrade:
    1080 x 607 - 1M
    Cant say when but eventually mcjFrameMaker will be able to create/use layouts with image/cells of different dimensions ( for now of dimension 1,2,3,4... )
    The second layout in the table has a layout described like this:
    [ 2011 ]
    [ 0020 ]
    [ 1100 ]
    The third layout in the table has a layout described like this:
    [ 3001 ]
    [ 0001 ]
    [ 0001 ]
    you could say that first layout is the only one that mcjFrameMaker can use for now
    [1111]
    [1111]
    [1111]
    1080 x 607 - 539K
    mcjFrameMaker V2 for Daz Studio... is coming out this weekend i suppose
    i'll possibly merge it with mcjSlideShowVideoMaker
    what's new:
    - variable image-cell-sized layouts
    - subtitles over picture-cells
    - subtitles above image-cells
    - sibtitles under image-cells
    - paragraphs of text on plain or textured backdrop
    4K Version of this image on my no-nudies non-deviantArt Gallery
    https://www.deviantart.com/mcasual/art/mcjFrameMaker-for-Daz-Studio-V2-free-Daz-script-937615401
    1080 x 607 - 1013K
    edited December 2022
    mcjFrameMaker and mcjSlideShowVideoMaker News
    this here shows that i found a way to present users of the next version of those scripts (they may be merged into mcjVideoMaker)
    ... with the complete set of possible and sane layouts for a given grid
    in this case a 3x2 grid
    there were 128 combinations of the 7 walls, and only those made sense
    and here's a recent video made with mcjFrameMaker and mcjSlideShowVideoMaker
    and this one which is less scary (for people scared of ghost pics )
    1024 x 341 - 15K
    edited January 2023
    Jan 4 2023 UPDATE
    example:
    The Origin of The Event known as The One Stolen William Shirt Accord Fiasco ( though it ended well ).jpg
    3840 x 2160 - 3M
  • Nice thank you
    edited January 2023
    Silver Dolphin said:
    Nice thank you
    Thanks!
    If you use it please post an image here so I know that someone other than me was able to use it
    FrameMaker doesn't need ffmpeg so it's easier to get running
    SlideShowMaker needs ffmpeg for video making, but it can also mass-frame pictures without it
    edited February 2023
    coming soon mcjFrameMaker Pro
    mcjFrameMaker + per-image Captions + Pattern-Based Frames-Builder
    4400 x 3300 - 7M
    1302 x 775 - 362K
