Will misfit hair items get fixed for Genesis 9?
RexRedRexRed Posts: 1,342
I have this problem with a lot of hair assets.
None of the autofit options correct it (that I could find).
This is "tousled hair" and I see it used a lot in the Daz gallery. It is like the skull cap fits correctly but the hair itself has been set for beard/face instead of head.
Is there a workaround that does not require too many steps?
1000 x 1000 - 785K
  • TobiasTobias Posts: 109
    edited October 2022
    I've seen that with any hair that has a separate haircap when you autofit it.
    The only workaround is to load it in without the character selected. Then move it to the correct position, morph it to fit the headshape and then parent it to the head, not fit it to the character.
    Post edited by Tobias on
  • RexRedRexRed Posts: 1,342
    edited October 2022
    How do I "morph it to fit the headshape"? Do you mean by hand, like with Mesh Grabber or something?
    It would stand to reason that if they can perfectly fit the skull cap to the head they should be able to fit the hair to the skull cap.
    Post edited by RexRed on
  • LeanaLeana Posts: 11,737
    Hair often has morphs to adjust it, so start with those combined with scaling/rotation/translation.
    Load the hair without the character selected. Use the translate tools to move it into place.  On the haircap there is usually several fit morphs (e.g. back of head, temples, top height, etc ). Use those to fit to the skull. Once it is set then right mouseclick the hair in the scene tab, then choose Parent (not Fit) and parent it to the head of the character.
    I have no idea why the cap fits fine but the hair turns into a mask.  Someone with more knowledge about how all this works may be able to explain it
  • felisfelis Posts: 4,344
    I think the reason the hair goes berserk is that it is using G8 rigging, and when the cap get autofitted  to G9 it get G9 rigging. And then it tries to match the G8 rig to the caps G9 rig - and fails terrible.
    I have considered if there is a way to convert the hair to G9 rig too without messing it up. A PA will probably come with a solution.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,229
    edited October 2022
    this will teach me to post before looking blush
    see this thread
    https://www.daz3d.com/forums/discussion/597396/tutorial-how-to-fit-poseable-hair-to-genesis-9
