Daz asking to reinstall content already installed
When I booted up Daz yesterday, when loading a scene I had made the day before, I got a notification which said that there were files missing and I had to reinstall them otherwise some things might look different. When I install them through the prompt, they get put into a Daz connect folder.
It was the genesis 8 starter essentials, which are definitely installed. Today I wanted to load a different scene and I got the same notification for the same files, but the installing only took a split second. What can I do? Can I just remove the daz connect folder and reinstall the starter essentials through DIM again? Or might there be a bug in Daz or something?
  • SofaCitizenSofaCitizen Posts: 1,896
    If you use DIM then you should be working offline in Daz Studio itself else Connect will try to take over your installations and often makes a mess of things.  I would recommend specifically uninstalling everything that Daz Connect has messed with (not just remove the connect folders) and then fire up DIM to reinstall those products.
  • vaaernvaaern Posts: 79
     Well I've not had this happen a lot before, I'll try running Daz offline and fixing the folders.
