G3 eyes for G8 & G8.1
HylasHylas Posts: 5,069
edited November 2022 in Freebies
You probably know that you can use G3 skins on G8/G8.1 figures. The only issue is that the eyes come out passable at best, completely broken at worst.
Here's a simple material preset that you can apply to your G8/G8.1 figure after applying a G3 skin, it should fix the eyes.
There are also some presets to further adjust the tint of the sclera and iris, according to your lighting set-up and personal taste.
The presets don't touch the UV, so it should work on female and male characters, as well as skins with non-standard UV.
In a few cases (most notably Ophelia 7 of the ones I tested) the preset will give your character milky white eyes. This happens when the original G3 eyes were set up without translucency.
If this happens, go to the surfaces Iris, Pupils, and Sclera of your G8/G8.1. Check which map is used in Base Color. Apply that same map to Translucency Color. This should fix it.
Have fun!
zip
zip
G3eyesforG8.zip
50K
1000 x 530 - 374K
1000 x 530 - 457K
1000 x 530 - 439K
Post edited by Hylas on
