Are VDBs broken as well as DFORCE in the latest NVIDIA driver? [Solved]
RexRedRexRed Posts: 1,342
My VDBs look like this...
No matter what I do I cannot seem to get the line out of the VDB.
1626 x 1626 - 341K
Post edited by RexRed on
  • Which version of Daz Studio is that?
  • RexRedRexRed Posts: 1,342
    Version 4.21.0.5
    edited November 2022
    Version 4.21.0.5
    I went back to an earlier driver and is still happened.
  • Is this affecting VDBs from mutliple products?
    This problem was affecting all of my VDB products, they all were chopped off about mid way down. No matter how I moved or adjusted the VDBs they got chopped off at about the same place.
    It happened even if they were the only object in a scene as well.
    I did a "clean" reinstall of the latest Nvidia driver and now it is fixed.
    It must have been because I installed an earlier driver over top of the new driver (to get Dforce to work) and then I reinstalled the latest driver over top of the earlier driver (I thought it was a fixed driver).
    Then I installed over that an earlier driver to (fix the VDB problem). The VDB cut off happened as well with the earlier driver.
    So, I did a clean install of the latest Nvidia driver and that fixed it.
    I have made this thread "solved" I hope this problem does not come back.
    I am running two RTX 3090s in SLI pooled memory mode.
    I thought maybe one 3090 was at fault but that is just a guess.
    Thank you Richard for reaching out to help!
