Files could not be found.
All of my hard drives died recently so I had to reintall daz and redownload all of my assets and when I was done, I set up everythind the same way it was before but whenever I try to open any of my files, I always get the message that none of the files can be found. Everything in the scene is just a grey box.
Help please.
  • I did try to fix it by pressing F2 and setting the proper content directory, but nothing changed even tho the proper directory was set up all along.
  • Tried to cahnge all of my library paths to the only one I got and it didn't work.
  • IceCrMnIceCrMn Posts: 2,130
    What way did you install your content?
    Manual
    Connect (logged in to Studio and installed inside running Studio)
    Daz Install Manager (DIM)
    or
    Daz Central ?
  • qq_81ee1a28qq_81ee1a28 Posts: 68
    edited November 2022
    Manual all of it, Just plopped all of the files in one Library, like I always did.
    Post edited by qq_81ee1a28 on
    Have you checked to make sure you didn't nest the folders accidently? Common problem with manual installs.
    also, do you have a screen shot of the error?
    Is Studio looking in the correct folder on the correct drive?
    just a note, don't login to Studio if you aren't using Connect.That can be problematic.
  • Yeah, I nested the folders, didn't know you can't do that, my bad. So problem solved, thanks a lot.
    You're welcome.
