D-force not working correctly
CMKook-24601CMKook-24601 Posts: 200
So I am working on a scene but everytime I I hit simulate the hair seems to disappear into the head?
I will note this seems to be an issue with using a Genesis 8 D-force hair on Genesis 8.1
Post edited by CMKook-24601 on
  • felisfelis Posts: 4,344
    Is the hair build for dForce?
    Are you simulatiing current frame or timeline?
    Are you simulating from default pose?
  • CMKook-24601CMKook-24601 Posts: 200
    edited November 2022
    Yes
    Current frame
    Tried both!
    So when i do a simulation using a scene that uses G9 it's fine, but the scnee having the isse is one in which I am using a D-forc hair for G8 on G8.1
    it also might be work noting that the scene involves a giant woman (like bigger than buildings) and thus she is at about 30000% size wise....
  • Okay, never mind I figured it out.... Daz didn't like preforming the simulation with a figure at 30000% size....
    You could simulate her in normal scale and then scale her up afterwards.
    Yep! That is exactly what I did... that is sorta how I figured out it was the size that was the issue, lol
    This tends to happen quite often where I run in to an issue get frustrated, seek help then find the solution LOL
