Help, Textures don´t feel like working along.
Heya.
I am looking to add a wooden texture to the roof of the van. however it doesnt actually show it, it just changes the colour when I load it in.
On the seperate side and middle panels I have added the same texture and it works like it should, the other surface settings are identical to the roof one, but it just doesn´t want to add it.
(see picture)
i´m still learning so would love to know what I am doing wrong.
1472 x 821 - 2M
  • felisfelis Posts: 4,344
    Is the roof UV mapped?
  • Odesza7Odesza7 Posts: 12
    edited November 2022
    I am not sure, how would I find out. it shows some scabble lines trough the UV viewport, does that count as being ''UV mapped''?
    Post edited by Odesza7 on
    Probably not, you need to see something that shows the layout of the polygons making up the roof - they show which bit of a map will be applied to which bits of the model.
  • Probably not, you need to see something that shows the layout of the polygons making up the roof - they show which bit of a map will be applied to which bits of the model.
    Like this?
    1468 x 821 - 588K
  • Like what? That isa  3D view, not a UV view.
    Yeah again, im not really sure what im looking for. I get this trough the UV viewport but can't make sense of it. is this what you mean? this is with the roof panel selected.
    1492 x 898 - 141K
    If the roof is it own surface, which it look like on a previous picture, then select the roof in the surface tab, and then click on UV map in the viewport. Then it will only show the UV map of the roof.
    When I select the roof, it guides to the RearInteriorCeiling tab. when I then open the UV viewport, it guides to the same map as I have shown before.
    1912 x 1016 - 745K
  • Where it says View By Node, at top-left over the UV view, select View By Material instead.
    that shows an empty white square.
  • Richard HaseltineRichard Haseltine Posts: 101,010
    In that case it isn't UV mapped, you woild need to use a modelling or mapping application to add UVs to it - not that hard, a planar projection from the Y axis (or Z, depending on the application) would probably suffice.
    Is this a freebie or a commercial product from another store?
    Sorry for the late reaction. yeah that did the trick, thank you! I still cant really explain it but hey if it works it works :)
