Is there a script to change resolution to base and high?
JamesJames Posts: 1,074
edited December 2022 in Daz Studio Discussion
Is there a script to change object resolution to base and high?
I do this a lot. So I need a script to make my workflow efficient.
Post edited by James on
  • tfistfis Posts: 129
    This would be nice.
    It could memorize the standard settings and then revert them. So you can switch all your models with a single click.
  • felisfelis Posts: 4,544
  • My ITF Dev Kits have scripts for changing resolution, works on anything with a subdivision modifier, not only characters. Although this says it's for Genesis 8 Male, the scripts aren't figure specific:
    https://www.sharecg.com/v/94141/gallery/21/DAZ-Studio/InTheFlesh-Dev-Kit-for-Genesis-8-Male
  • I watched the 3DUniverse tutorial video for the product linked above, and that final script it creates in the toolbar, the one to simple toggle switch between base resolution and high resolution for all scene actors literally should be standard functionality in the app. I export everything to zbrush to make tweaks with the GoZ plugin, so that one script is a game changer, especially for someone who has accidentally exported in high resolution, finished a sculpt, and then discovered I can't import my sculpt because it was done on a high res mesh. It is so deflating to be told all of the work you've just done was wasted time.
    Anyway, thanks for sharing. Definitely going to pick that script package up.
