UV Atlas for Genesis 9 Anatomical Elements
![winddancer6440](https://delorean.daz3d.com/forums/uploads/userpics/591/nKL62P7VD0TVY.jpg)
Is ther a more detailed uv map for the G9 Female gens?
I have been trying to use the ones provided in the dev kit but they do not convey where the top of the texture is to be placed.
Or where to put the top line. It would make for easier texturing.
The only templates I'm aware of are the ones that come with Genesis 9/V9
You should be able to create your own - export as OBJ, open in a modeller or mapping tool (I imagine Blender would do, Hexagon too), and export the template as desired.
I have most of it worked out just some issues with legs and genital leg border.
Seems all previous versions came with better UV Maps. Hopefully they may put some out.
I do appreciate the feedback you all.
I made a set using StitchWitch [fancy borders] - if interested they are over at Renderosity.
"Templates for G9 Base UV Set by PetuniaPetals"
There are no gens templates in Genesis 9 Starter Essentials nor in Genesis 9 Anatomical Elements nor in Victoria 9 HD, which is a mistake in my opinion... (There are UVs in G9SE, which is a different thing).
