All figured out..
MjvolMjvol Posts: 93
edited October 2015 in New Users
Hello Discussion ended.
Peace.
Post edited by Mjvol on
  • LinwellyLinwelly Posts: 5,989
    You can change the settings for the size and format in the render settings under general. So if you want to scale your render up I suggest you load your scene again and change the render settings , maybe to something to 600 or 800 pixel, with better renders I use 1000 and even higher. I hope that helps. I have to admit I never encountered the problem of a too small render, which lets me think about of you used the correct render or maybe the thumbnail to upload?
  • Did you render and save the render, or did you just use File>Save which saves the scene with a 91 pixel thumbnail?
  • MjvolMjvol Posts: 93
    Yes you are right , I did load it up from the file that I saved in and it is about the size of thumbnail, I just thought it would be proper size , but thank you I will look into that render settings if I can figure that out. But thanks for the comment and taken your time out. Take care
    Mjvol
    Your welcome, it's a lot to take in the beginning
    I think I just figured it out with the help of Linwelly, hopefully this works..
    509 x 466 - 406K
    mjvol said:
    I think I just figured it out with the help of Linwelly, hopefully this works.. yep it worked thanks all,  and thank to you  Linwell
  • barbultbarbult Posts: 24,878
    Look how far you've come from being ready to quit a few days ago!
    Great that it worked! Its good to give some of the help I received here and still receive to someone else
  • pwiecekpwiecek Posts: 1,582
    FYI, once you render and have a picture (or an animation) you are now OUT of the Realm of Daz Studio. If you want to change it, you have to render a new picture or use Photoshop or the GIMP.
  • KharmaKharma Posts: 3,214
    Congratulations on your first posted render!  You have hurdled the basics and are well on your way to creating wonderful artwork!!  :)
  • dHandledHandle Posts: 617
    I remember doing that tutorial and being massively impressed!  It's a good one for dramatic impact.
    I remember using the same set (without the dragon and warrior) with a female mage from a different angle, and seeing the blank alpha channel info where the doorway to that underground chamber was.  I I remember I experimenting with different backgrounds and imagining the possibilities...
    You could put anything outside that dungeon!
    1280 x 720 - 326K
    1280 x 720 - 336K
    Hey that looks neat, yea same set I used.. well done
    Yes your right. I am learning , And as time goes on who knows.
    Thanks
    Mjvol
