New install of Hexagon only shows part of interface
edited January 2023 in Hexagon Discussion
Yesterday, opened Hexagon 2.5 (the latest version) all that was on the sceen was the material, scene, and properties panels. The main interface screen was not there at all. I unistalled Hexagon, re-downloaded it and installed it again 4 times. each time rebooting the computer after the uninstall and after new install.  I even tried loading it into a different folder on the C drive.  I'm using Windows 10.  I've never had this problem before.  I am using 2 monitors and it doesn't appear on either monitor.
  • Richard HaseltineRichard Haseltine Posts: 101,482
    edited January 2023
    Moved to Hexagon Discussion as it is not a Daz Studio topic.
    If the issue is a damaged interface setting then uninstalling and reinstalling won't help (that should never do anything to user settings). I am not certain but I think probably the two usergui.xml file in
    %appdata%/daz 3d/hexagon 2/
    is the one with the layout - try removing that, with Hexagon closed, and then restart. I suspect the usergui_save.xml file is a back up the previous state, but after restarting several times they may both be the same anyway
  • Catherine3678abCatherine3678ab Posts: 8,365
    edited January 2023
    C:\Users\...\AppData\Roaming\DAZ 3D\Hexagon 2
    If you can try switching to another layout maybe it would bounce back? {I have not experienced this with Hexagon. It's not a field we can open/close.}
    There are some very tiny "arrows" which hide/show the various side/top/bottom panels.
    1920 x 1026 - 248K
  • edited January 2023
    The problem is that the main interface isn't there at all.  It looks like it flies off the screen to the left when I minimize the other panels but it's so fast I can't tell.
    edited January 2023
    Are you talking about the large centre part? A screenshot of some kind would be helpful.
    Attached a zip -- unzip -- a Hexagon file.
    zip
    zip
    Try Opening This.zip
    612B
  • Yes. The main program screen is not there at all. I'm not at that computer now but I will include a screenshot tomorrow when i can
  • Okay.
    Maybe somebody else knows what can cause that.
    Just to confirm, does your system meet the basic requirements?
    https://helpdaz.zendesk.com/hc/en-us/articles/115005642306-Hexagon-2-5-System-Requirements
    Yes.. Windows 10  It was loaded and worked before
    Okay.
  • Okay, that's good.
    Then with it installed, are you able to open the .hxn I attached to a few posts back? Hoping that my scene file might jog the memory in your Hexagon to open the same way.
  • edited February 2023
    I can't find that file %appdata%/daz3d/hexagon2/  I used Command prompt to shell to dos and searched the C drive but nothing
  • C:\Users\...\AppData\Roaming\DAZ 3D\Hexagon 2     AppData is a hidden folder. OS settings have to be toggled to show hidden folders.
    If you paste the path into a file browser the system wille xpand the %appdata% part into the correct path and should open the correct location.
