Tutorial: How to Fix Oneiros
mdingmding Posts: 1,278
Oneiros is a beautiful and versatile product but for whatever reason geometry has been lost at 2 places.
 If you can’t wait until it gets fixed by DAZ and lack the knowledge to do it yourself, here is a step by step solution for those who may need it:
You need Hexagon installed on your computer which is free in DAZ, but you don’t need any further knowledge.
In DAZ Studio:
1. Load the Prop Oneiros in DAZ.
2. Click on Oneiros in the Scene Tab to select it (yellow)
3. Click „Send to Hexagon“
In Hexagon:
4. Click „ok“ on the Hexagon News Window
5. Click on „Oneiros“ in the Scene Tab (it turns blue)
6. Click on „on_base_bot_s2“, that is the second entry in the Shading Domains Tab (it also turns blue).
If you can't find the shading domains tab you can activate it in the WINDOWS menu:
7. Now Click „Cut“ (ctrl+x) and after that „Paste“ (ctrl+v) in the EDIT Menu.
 In the Scene Tab appears now the second entry „Form1“ and it has turned blue (which means „selected“)
8. Now in the „scene tab“,  to the left of the first entry „oneiros“ click on the eye symbol
the main part of the prop is now invisible:
9. In the Viewport click on „Perspective View“ and then choose „Top View
You see the Prop now from above:
10.In the Viewport Utility Bar click on „Wireframe
The prop looks like this now:
11. Press F2 (OR click on „Select Faces“ in the "Selection Type Bar")
12. Click on „Rectangle Lasso“: This Lasso selects only the parts which are completely inside of its‘ borders.
13. The Prop consists of 4 parts, a tiny one and 3 long ones:
With the scroll wheel of your mouse you can zoom in and out.
With the right mouse button you start the selection.
You have to select the first two long parts with the missing geometry ("3" and "2" in the screenshot above)  by placing the rectangle around them and avoiding to place the other two parts completely inside that rectangle. Start from the bottom like so:
14. Now both broken parts are selected.
15. Hit Delete (NOT Backspace) .The selected parts have been deleted
16. In the same way select the tiny part, choose cut and then paste in the Edit Menu.
17. EDIT: forgot to delete this step before posting, so please ignore.
18. In the Scene Tab you can see now
„oneiros“ = invisible rest of the prop,
„Form1“ = larger part and
„Form2“= tiny part
19. With „Form1“ selected, type ctrl+c (copy) and ctrl+v (paste). A new „Form1“ has been created and selected.
20. Inside the „Properties“ Tab, in the green column, in the „rotate“ row enter „–45“.
Your scene looks now like so:
21. With the new „Form1“ still selected copy and paste again (like in step 19) and enter into the same place like in step 20 the value „-90“. Your scene looks now like so:
22. Select the second "Form1"…
23. ...and change from "Top View" to "UV View":
24. With the scroll wheel of you mouse zoom in a bit to better recognize the selected area („uv island“)
25. Hit F2 to choose Face Selection…
26. …and with right click (holding) select the selection (uv island) completely
27. Hold ctrl, then left - click (hold) on the green arrowhead and with the mouse move the selected area onto the texture part right above the previous one
28. Click on the last „Form1“ in the Scene Tab
29. Select the „uv island“ as in step 26 and move it this time to the texture above the one chosen in step 27
30. Choose again the „Top View“
31. Click on the eye symbol of oneiros
32. Select all nodes in the scene tab
33. Click „Send to DAZ Studio“
Back in DAZ Studio:
34. Click on „Create a morph“ and choose „Create a prop“ in the forthcoming menu and hit „Accept“
35. Repeat with the next dialogboxes until all parts have been processed
36. Delete the original oneiros prop in the scene tab
37. Select „oneiros (2)“ in the scene tab and load the RSL material onto it. This is necessary, as the IRAY material is broken concerning the windows.
38. Oneiros now ready to be further adapted to your scene.
712 x 552 - 576K
705 x 716 - 587K
641 x 629 - 534K
1254 x 532 - 873K
640 x 581 - 515K
361 x 391 - 30K
250 x 351 - 13K
991 x 774 - 75K
404 x 383 - 35K
597 x 312 - 85K
495 x 238 - 61K
411 x 506 - 63K
334 x 338 - 145K
881 x 909 - 962K
1143 x 918 - 717K
685 x 558 - 56K
Post edited by mding on
  • My method to fix Oneiros:
    Export to Blender
    Create the missing faces
    Tweak the UV until the joints match
    Export to Daz
    Copy the surfaces from the original Oneiros to the fixed one
    Use the Transfer Utility  to retrieve the bones
    Done!
    2560 x 1440 - 5M
  • mdingmding Posts: 1,278
    Export to Blender
    Export to Daz
    Done!
    Unfortunately, i am too much of a beginner to do that. What you just wrote may be easier, but i couldn't even try to follow your steps, because i lack the knowledge. That is why i created that tutorial, so others, who are in a similar situation can get access also to oneiros.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,576
    I thought I would be clever and show you a DAZ studio only way but it was not easy as nothing is lined up xyz
    with geometry editor selected select the matching faces the other side
    invert selection and hide
    scale it -100 on X axis
    edit flip normals
    export that as obj no hidden checked
    import it and uhmmmmm line it up, this is the messy impossible bit blush
  • AgitatedRiotAgitatedRiot Posts: 4,437
    Glad I don't have that model
    edit flip normals
    yeah, i also at  first  in my frustration thought of creating separate faces in daz and closing those stupid holes, using a new texture for that entire wall, lol. It never looked good...
    It is really a beautiful model and those steps should take less than 10 minutes (i do it in 5). The tutorial is just a bit bloated, because it is done for people who never even touched Hexagon. Whoever knows how to model doesn't need a tutorial, right?
    Sure your tutorial will be useful for the ones that use Hexagon! Thank you!
    I'm too lazy to make a complete tutorial about the method I used, and I'm not really a Blender teacher :)
    @rosseliani: I totally understand, i wouldn't have done a tutorial, if i wasn't a fan of that prop, lol. And some day in a far future i may be able to understand what you explained. It is true that in the longer run we all will have to learn blender.
    yeah Carrara it's a 2 minute fix in the vertex modelling room too
    @WendyLuvsCatz: that would be a new reason to buy carrara: the fastest way to fix your broken DAZ products laugh
