Editing Textures?
The good news: Daz users have created models that resemble my unusual characters.
The bad news: They are all supposed to wear pink maid uniforms, and the closest match I've found only comes in black.
The textures are saved in a compressed file called DSON which google is telling me is text based. I'm used to editing 3D textures in photoshop/clip studio/etc., not text documents. Heeeeeellllllp!
  • Cris PalominoCris Palomino Posts: 11,391
    It would help to know to which products you refer. Textures are normally image based; does your product not have them?
  • felisfelis Posts: 4,341
    I would assume that that file is just a reference to the textures.
    What does it look like if you open the file with 7-zip and then Edit?
    And are you able to load the object in Daz Studio? If so then go to the surface tab and look at that.
  • GordigGordig Posts: 10,062
    edited January 2023
    More specifically, it's probably the material preset.
    To the OP: open the Surfaces pane with the object whose textures you want to edit selected, select a single surface, and hover over the base color map slot. It will display the location of the map itself, which will be located in runtime/textures/(PA's name)/(product name)
    Post edited by Gordig on
