Iray Render Settings
Hi guys,
i have a problem with my iray settings. I make for exampel g2f with Bot Amor which have normal a chrome effect. But everytime when i rendered the chrome effect isn't visible. And the other problem is the ground or something like a wall, they are like a mirror and i dont know why. I hope someone can help me.
Greet
Kayto
ps.: you can see my profile picture, these is the botamore but thats a render before iray exist and there u can see the chrome effect, but with iray u cant see it :/
Post edited by kayto93_073094d40c on
Have you changed the 3Delight shaders into Iray shaders?
yes i have and the renders looks really realistic but only the metallic shaders dont work i dont know why. I made exampel rendering
Check the 'Metallicity' setting for those areas. You can set it all the way to maximum for shiny metals.
Ah okay i saw now and for the areas which i want to glow there i use the Emissive shader. So i have to make everywhere a new shader or not?
Yes, you need to apply/convert all the existing 3Delight shaders/presets to Iray versions. There will be a selection of Iray presets in your content library to get you started.
