Export rigged character to Houdini
I've tried in different formats with no luck, in most cases not even get it properly texturized.
Does anyone get it work?
Thank you.
    edited August 2015
    What formats are you trying to use?
    OBJ does not carry rigging information, so it wont work, FBX or DAE (Collada) are your best bet, have you tried these?
    What character are you trying to export, Houdini probably does not use the same rigging system as DAZ Studio anyway?
    Post edited by JimmyC_2009 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,624
    FBX will work but you would have to manually add the textures
    I had Houdini apprentice once on my PC and was able to bring rigged DAZ content in but have removed it long ago
  • farylolfarylol Posts: 3
    edited August 2015
    FBX and Collada seems to export a bad quality mesh and rig seems to be incompatible with Houdini. I had to import the Obj and retexturize but I'm having problems with the eyes, the lashes are solved but I can't make the iris, pupil etc look properly.
    Sorry for my poor english and thanks for the replies.
    Post edited by farylol on
  • Which figure? The figures before Genesis 3 Female used a form of rigging that was not compatible with FBX (or most other applications) so they had to convert to general weight maps with inevitable loss of quality.
    The figure is Victoria 7 HD.
