anyone knows how to fix this?
invisigoth
today, i opened the MistyLara Janette for Carrara , which usually work, but got this
760 x 778 - 288K
just tried mine and loaded fine..
only guess is that the location for G3 F morphs on your hard drive has changed since you last used it successfully
any idea how to fix it? lol
Simple! Just make sure the morph packs exist in the same directory structure from which you launched Janette
also, i keep getting this error "Error: node name://%40selection/Genesis3Female: not found"
Then that is your solution. The Misty preset is not the problem, but possibly the data folder it is referencing. Start from scratch. I've done that alot.
just move the Genesis 3 data folder and reinstall the starter essentials
your drive:\My DAZ 3D Library\Data\DAZ 3D\Genesis
test then add back all the additional morphs until you find the culprit
can do it in alphabetical blocks
however if it works in DAZ studio it may be your path in Carrara
in which case you may need to delete your browser link and readd it
now i keep getting this, after adding shaders ... any idea?
sorry for all the problems, i stepped away from carrara for a couple years, and now it's like i need to relearn it all over again
usually happens to me when the saved file size is nearing or more than 4 gig ... which happens a lot if using Genesis and not clearing out unused objects and shaders .. some have success by changing the file name extension to zip and unzipping the contents but it has never worked for me. So I just try to keep my file sizes as low as possible.
there isn't anything in the scene
