Daz Studio/Bryce Bridge version select has no version
![Boojum the brown bunny](https://delorean.daz3d.com/forums/uploads/userpics/301/n1903C9A90371.jpg)
Ok, maybe someone can help me with this. I have just installed my version of Bryce 7.1 Pro and all it's content. I have the latest version of Daz Studio Pro installed. I have verified that the Daz Studio to Bryce bridge present. When I open Bryce and click the Daz Studio symbol, I get a "Select version of Daz Studio" panel with a dropdown. The dropdown has no versions to pick. Any ideas on how to get this working?
Thanks,
Boojum
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/52/53e68b4239335071bde86d6e7c180b.png)
299 x 149 - 51K
Have you tried the reverse diection?
Ok, it turns out I don't have the latest version. the latest version of Daz Studio in Install Manager is 4.2. Anyone have an idea on why 4.5+ isn't there? I know that the new Daz Central I was told to not use because it doesn't install a bunch of stuff I needed.
OOOookaaay.. and Daz Central also only offers Daz Studio 4.2. Now I'm confused.
No, this is the right version. It's Daz Studio 4.21 not 4.2. Why am I not getting an option to pick it??????
Ok, other way works. I just launched Daz Studio 4.21 and sent to Bryce.. and the Girl arrived in bryce. So at least I have a work around.
Hi Boojum, I always work Bryce to DS. Richard said to try DS to Bryce but I have problems with that. I end up using DS to make my figure then export it as a Bryce object. I prefer Bryce to DS.
Did you install DS first or Bryce first? I thought I heard that it makes a difference.
Version numbers are not decimals - they are whole numbers separated by dots (4.21.0.5 is the current General Release).
Hi NGartplay. I had Daz Studio installed, then I installed Bryce but the Bryce to Daz Studio didn't work. I thin uninstalled Daz Studio, and reinstalled it. Bryce to DAz Studio still didn't work. After some earlier advice, I tried to open a character in Daz Studio and send it to Bryce. That worked. It seems the other direction is broken however.
Once I got the character into Bryce, I saved it off as a Bryce file. then I could create a new Bryce world and import the figure in using the merge option.
Thank you Boojum!
Maybe this helps:
https://www.daz3d.com/forums/discussion/comment/150757/#Comment_150757
Hi Kerya, nice to see you. Thank you for the link.
