DS 4.5 Darkside skin, why cant I see ALL paramter values in a single list?
StratDragonStratDragon Posts: 3,168
Using DS4.5, the one that's no longer an RC. Windows 7 64 bit.
When I use the Darkside interface and click on the root of an item in my parameters tab I only see the "What do I do?" pane.
Any other interface will show the list of all parameter sliders, just not Darkside.
  • adamr001adamr001 Posts: 1,322
    Hmm, I seem to see them all on Darkside. Not certain why yours isn't working. Have you tried a different layout just to see?
    450 x 697 - 34K
    Did you install the Darksied download that came with 4.5? If so, that might be a problem as it is already contained in the main installer. You probably knew that though, just a thought.
  • StratDragonStratDragon Posts: 3,168
    I did a clean install from my Windows PC, I didn't have 4.x anywhere when it was executed so anything contained should have been part of that single installer instance.
    I tried to do a clean install on my Mac as well, it appears the installer does not proceed past the uninstall portion unless 4.x is present.
