Change shapes value
semidieusemidieu Posts: 26
I want to work with the Genesis shapes.
Looking for the samples, it's easy to get all the shapes (Property) of the currently selected figure.
Now, I can't seem to find a way to:
Get the current value of a shape
Get the minimum and maximum value of a shape
Set a value for a shape
Thanks for your help!
Basil
  • Richard HaseltineRichard Haseltine Posts: 102,130
    For a morph oModifier,
    oControl = oModifier.getValueChannel();
    will give you the parameter. then you can get values, limits and whether they are on with
    value = oControl.getValue();
    limited = oControl.isClamped();
    max = oControl.getMax();
    min = oControl.getMin();
    and set the vlue, or change the limits, with
    oControl.setValue( value );
    oControl.setMax( max );
    oControl.setMin( min );
    oControl.setIsClamped( true );
  • semidieusemidieu Posts: 26
    edited August 2012
    Thanks for the reply... Now... I'm discovering that I'm really missing something.
    I used the sample: Node Properties.dsa
    This displays the list of morphs. But I can't get further from here... I'm thinking I'm doing the things wrong here...
    So, I think I must handle things differently... if I start with:
    oSkel = Scene.getPrimarySelection().getSkeleton();
    Is there a way from here to get the list of all morphs and then handle the values ?
    When I look at the sample (Node properties.dsa), it looks to me very complicated to get all the morphs like this... I'm sure there must be a much easier way...
    One last thing: Is it possible, in the Script IDE, to run a command to list the available functions for an object ?
    Something like: help(oNode);
    Post edited by semidieu on
    Ok... found it! But why does this code generate an error at the end ?
    // DAZ Studio version 4.5.0.114 filetype DAZ Script
    oNode = Scene.getPrimarySelection().getSkeleton();
    var obj = oNode.getObject();
    for (var i=0;i
    And there error is:
    ... lots of line above...
    FBMBasicChild0 1
    CloneVictoria40 0
    CloneTheGirl40 0
    CloneStephanie40 0
    CloneRebySky0 0
    CloneMichael40 0
    CloneKids40 0
    CloneHiro40 0
    CloneFreak40 0
    CloneAiko40 0
    Script Error: Line 10
    TypeError: Result of expression 'modifier.getValueChannel' [undefined] is not a function.
    Stack Trace:
    ()@:10
    Error executing script on line: 10
    Script executed in 1 secs 172 msecs.
    edited August 2012
    Notice that the error happens for
    i=926
    And for information: obj.getNumModifiers() --> 927
    I'm posting too fast - found the solution! getModifier can also be something else than a DzMorph. Added a check for this and it's working now!
    Heh, well you saved me from having to reply - but yes, you do need to check the type of the modifier.
