so do all extreme shapes for G9 made clothing need templates?
WendyLuvsCatzWendyLuvsCatz Posts: 38,228
I transfered a couple of shapes over from Genesis 8 to 9 using clones and autofitted or transfer utility rigged clothing fits fine
up until yesterday I didn't own any actual made for genesis 9 clothing
I quickly discovered the genesis 9 clothing does not fit my transfered shapes nicely
are extreme G8 ones like Dolb and Ebeneezer
I see they come with templates like Michael9 and Victoria9 etc as well as portly, stocky
I had issues with Sickleyield's 200 free morphs too
they all fit V9
  • lilweeplilweep Posts: 2,489
    edited March 2023
    the geometry of clothing wont change when tranferred to G9, so im thinking that any supporting FBM morphs (for G8 figures) on the original G8 clothing could be used.
    So wondering if you could just try transferring any existing FBM from the G8 clothing to the G9 clothing.
    In transfer utility you can transfer favorited morphs, so could try that... or do it manually.  If the FBM have same name as your G8 morphs on your G9 figure, then wont need to play around with ERC since the FBM will autoload when dialing in the corresponding morph on the figure.
    Post edited by lilweep on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,228
    what it does is mess up rigid bits like leg guards, plates, buttons etc
    sink into it, translate away
    another option could be to convert to prop and use the transfer utility
    then it will autofollow
