I work in DS on several computers each with its own local library.
Are there any special considerations that apply to using Dial Fusion in this situation? Would I need to copy [something unique to Dial Fusion] between computers in order to, for example, set up a project on PC "A" using Dial Fusion, but use PCs "B" and "C" to render it?
thanks,
/t
As long as the created dial can find the morphs used inside the library then it should be fine.
Hello. What I'm hoping to do is save the final shape of G9 figures initially created by ManFriday's Figure Converter for Genesis 9, along with any subsequent tweaks made by regular morphs in G9. In my initial testing, Dial Fusion doesn't seem to see the converted shape, which appears to be located in Parameters - Figure (eg, "Genesis 8.1 Female Converted to G9") - Figure Converter. Is that an area it doesn't use? I have fairly minimal experience with any of the Dial Fusion products so apologies if this is a stupid question.
thanks,
/t
Can this be used for body pose dials, such as bending an arm or kicking a ball?
No. It is designed for shaping only.
Hello. What I'm hoping to do is save the final shape of G9 figures initially created by ManFriday's Figure Converter for Genesis 9, along with any subsequent tweaks made by regular morphs in G9. In my initial testing, Dial Fusion doesn't seem to see the converted shape, which appears to be located in Parameters - Figure (eg, "Genesis 8.1 Female Converted to G9") - Figure Converter. Is that an area it doesn't use? I have fairly minimal experience with any of the Dial Fusion products so apologies if this is a stupid question.![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
Hi. I do not own the Figure Converter to verify the issue. Sorry.
