Daz3d Not rendering at all
Daz is not rendering anything at all. even just simple basic one G8 model. Couple of hours ago it was working fine. I restarted Daz, pc itself. not working. I though it was Vram problem but it's not(I tried to render already rendered scene but now it's not working).
It's just stuck like that. bar is moving infinitely
While i try to render it's just black screen and in log files it gives me this error
2023-03-12 21:28:22.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: OptiX Prime error (Device rtpModelUpdate BL): Memory allocation failed (Function "_rtpModelUpdate" caught exception: Encountered a CUDA error: launchAPMInit() returned (2): out of memory)
2023-03-12 21:28:22.292 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): Scene setup failed
2023-03-12 21:28:22.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): Device failed while rendering
2023-03-12 21:28:22.293 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - IRAY:RENDER ::   1.5   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce GTX 1070) ran out of memory and is temporarily unavailable for rendering.
2023-03-12 21:28:22.301 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [WARNING] - IRAY:RENDER ::   1.5   IRAY   rend warn : All available GPUs failed.
2023-03-12 21:28:22.301 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: Fallback to CPU not allowed.
2023-03-12 21:28:22.301 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: All workers failed: aborting render
2023-03-12 21:28:22.301 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): [Guidance sync] Failed slave device (remaining 0, done 0).
2023-03-12 21:28:22.302 [ERROR] Iray :: Internal rendering error.
2023-03-12 21:28:22.549 [INFO] :: Saved image: D:\\Applications\Data\DAZ 3D\\DAZStudio4 Temp\render\r.png
2023-03-12 21:28:22.566 [INFO] :: Finished Rendering
2023-03-12 21:28:22.617 [INFO] :: Total Rendering Time: 14.23 seconds
2023-03-12 21:28:44.771 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
2023-03-12 21:28:44.771 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce GTX 1070): 0 iterations, 0.113s init, 0.010s render
I even reinstalled daz but still nothing. Im out of options.
1920 x 1002 - 318K
  • Richard HaseltineRichard Haseltine Posts: 100,990
    Will it, after restarting Daz Studio, render a simple cube or sphere (Create>New Primitive) with the default settings? Are there other applications or games running that use the GPU?
  • xinkaliaxinkalia Posts: 10
    Well cube works.Soo Vram problem? I don't think so. I can't even render scenes that I already rendered without problem before this happaned
    edited March 2023
    Now not even cube is rendering. One moment it's works and then it can't render simple cube
    Post edited by xinkalia on
  • Will Daz successfully complete a render if you tell it to use only the CPU for rendering?
    yes
    The log says "Out of memory" = Your GPU doesn't have enough VRAM to render the scene
    Im just rendering a basic G8 figure nothing else
    No hair, no clothing, nothing?
    How much VRAM does your card have?
    nope just basic G8 without enviroment hair clothing
    8GB
    That's 8GB on a non-RTX GPU, which means you get just around 3GB's for Iray rendering.
    Depending on the texture size and SubD, that may be too much for your card.
    I have rendered much heavier scene with 4 G8 figure with hair, clothing environmet and multiple light sources.
    With the same version of DS, same GPU drivers and same textures and SubD on the characters?
    yes on same settings
    What does your log say, from starting DS to end of rendering?
    Do not copy the log to the message area, but attach a text file to your post.
