Hiya! A new problem O.o
in New Users
So Ive been fiddling grabbing lots of freebies, getting them inserted into my library to make everythign loadable, Very tiem consuming! But anywho. Been using Daz for something like, Four months now? But ran into a new issue. I was flipping thru different pose packs i grabbed and suddenly my Model like, Broke O.o. I mean i cant click her but i can click her hair and one shouder but I simply cant click on her anymore, I ensured i clicked the posing buttens at the top that allow me to move and pose as i need but Nothing happens its like, Nothing is there. Theorys? And apologies for the typos fighting sleep till i figure this out.
You may have accidently clicked the small check mark in front of the character in the "Scene" tab.
Check to see if that is is an "x" instead of a check mark, it makes that item un-clickable in the viewport if it's an "x" .
Thanks! That did it exactly, Never noticed that before somehow, One more question, And thank you by the way. I added some outfits Via some freebies, They are supposed to have Sliders, But the Side box where they all appear there is nothing, Due "My Library" Items not get Sliders or did I mess up the install some how? I simply unzip, go into the content and drop all into My Library right?
You're welcome,,,
Do you have your outfit selected, or the character?
The outfit. on all my official outfits installed thru DIM they get sliders even if its just a single one, But with these its just blank on the panel where the sliders normally are
Well, it sounds like you have them installed correctly, or they wouldn't load for you.
So let's have a look at the "Parameters" tab while you have the outfit selected.On the top part there are several choices, "All" "Favorites" and "Currently Used". If you have "Currently Used" selected the list maybe blank.Try selecting "All" or just click the outfit in the list under "Currently Used" and see if that makes the sliders show up.
When I go to Paramiters tab, Click teh clothign item i see the basic ones, Sub Level, Interactive update, Collision, Show bones ect, But no sliders that are supposed to be there, Like Clothing Shape sliders.
sadly ,, not all freebies have extra adjustments.Some load in an "as is". If you could let me know what one you are working with I might have it, and I can check to see if there are any we might be overlooking. I think I download most of sharecg :)
Lemme see if i cant find the link again and ill send it your way ^.^
Okay you were right, This free version didnt have the sliders, I grabbed so many freebies last night I had my downloads mixxed up. Here is a new question, One of the uhm.. Cyclorama? Packs i grabbed has a Manifest file and a long number, SUpposedly i can use this to install with DIM as opposed to simply dumping in My Library but the arthers page simply says to install normaly. Any advice or should I simply try to bug the creator?
If it is from Daz 3D and has a number that says IM00001234 (or what ever numbers) then it can be installed through DIM
@.@ This is all so confusing, Like when i first learned modding
If the zip came from the store you can copy it to the DIM downloads folder, and when you start DIM it will be in the "ready to Install" tab.
otherwise you would need to unzip it somewhere you can have a look inside to see how its put together.Some freebies can be a real mess, so it's a good Idea to have a look in side them before you dump them into your library.
