DAZ Script: Access To Iray Render Settings?
![3dcheapskate](https://delorean.daz3d.com/forums/uploads/userpics/662/n0HSNEA3VB7BJ.jpg)
Specifically the parameters in the Render Settings > Editor > nVidia Iray pane, such as Environment Mode, Dome Mode, etc.
As far as I can see there's no DzRenderer or suchlike class in the DS4.x online Object Index docs, (although there may be something buried inside something else,or it may be as yet undocumented...)
Post edited by 3dcheapskate on
-Rob
Thanks Rob, that'd be it.
Using Rob's sample code I've got the properties I want. Now I look under DzProperty and reckon I need to do getAttributes / setAttributes, but the essential propertysettings_dz is as yet undocumented. I guess it's similar to the old DS3 DzSettings? So with a bit of educated guesswork I set up oProperty using Rob's sample code with "Environment Intensity" as the string and do this...
var oPsettings = new DzPropertySettings;
oProperty.getAttributes( oPsettings )
print('>>> oP "Environment Intensity" = ',oPsettings.getFloatValue())
...(I know getFloatValue requires parameters - I'm getting to that) and I get this...
DEBUG: Found: Environment Map
WARNING: Script Error: Line 1839
WARNING: SyntaxError: too few arguments in call to getFloatValue(); candidates are
getFloatValue(QString)
getFloatValue(QString,float)
In the old DS3 DAZ Script 2 documentation it gives this
Number DzSettings::getFloatValue ( String key, Number def = 0.0 )
Parameters:
key The key string.
QUESTION 1: What is "the key string" ?
QUESTION 2: Am I heading in the right direction ?
{Edit(20Nov15): I've copied this post to start a new thread "Undocumented propertysettings_dz - is this the same as the old DzSettings? What's a key string?", since other than the context of what I'm trying to do it's far more general than just Iray render settings}
