How to repair bent arms and twisted wrists?
![zhiheng](https://secure.gravatar.com/avatar/65d2c60490a73de1ea1429c729c730f6?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F65d2c60490a73de1ea1429c729c730f6_100.png)
[How to repair bent arms and twisted wrists?] Please see the attached image. I did not make any changes after importing, only redirected the bones.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/7a/ebc9b26859fecca86a71d0c81cc0d8.png)
668 x 675 - 693K
Looks a if it is overtwisting now - adding a full rotation instead of just the desired partial rotation, you may have twist applied to a bend bone, with a more limited transition in the weight map from 0% to 100% and there are two few loops to accommodate the effect.
Thank you. According to your method, I solved the problem with this animation, but caused other normal animations to appear distorted. It doesn't seem like a perfect solution.
