DAZ to Cinema4D Bridge installing
reza-design
Hello,
I have a problem with the installation of DAZ to Cinema4D R26. That doesn't work at all in DAZ Central. The wheel spins for minutes and then I have to restart. I think I can do that automatically or manually in the DIM, but I don't know how to do it. This is a qualitative gain for me if I learn this. I work a lot with Cinema4D. I will be very happy if someone writes me exactly what I can install DAZ to C4D Bridge. I use Apple Macintosh (attached).
Thanks very much
Gh. Reza
596 x 359 - 80K
I don't think Central can install plugins, though I could be wrong about that. In any case, it's definitely recommended to use DIM across the board.
thanks for your writing, I think you are right. I haven't had any problem with DIM so far. But still my main problem remains. I don't know how to install DAZ to C4D in DIM. DAZ to C4D does not come in the DIM.
(Sorry for my bad English, it's goole's fault).
I either missed this post, or the answer didn't occur to me. Go into the Advanced Settings in DIM, click the Downloads tab, and make sure to check Cinema 4D under Application Tags (and probably Plugins under Install Type Tags).
Hello Gordig,
sorry for late reply. I did everything as you said. C4D isn't in Application, I don't know why. Attached are pictures of it.
Thanks a lot for your help
I use Apple Macintosh.
According to the product page, the bridge only supports High Sierra. Then again, it also lists 4.10-4.12 as the supported versions of Daz Studio, so it clearly hasn't been updated in quite some time. I'm not sure where you'd go to find the answer to this, but it's possible Monterey isn't yet supported. As for the Applications tab of DIM, I don't remember whether that populates with C4D when you install and run the bridge or if you have to add it yourself. Click the little plus icon in the bottom left, and you should be able to add the information for your C4D installation.
