Question about the bow in archer khan poses for genghis
hi,
are thre fitting poses or the bow from https://www.daz3d.com/elf-ranger-outfit-for-genesis-8-and-81-females for using on https://www.daz3d.com/archer-khan-poses-for-genghis-khan-9-and-horse-3 included or doesn't it matter which bow and arrows you are using here?
  • vwranglervwrangler Posts: 4,889
    There are no poses specific for that bow and arrow set, no. As far as I can tell, it doesn't matter which ones you use; you'll need to pose them yourself anyway.
    It's also going to be a little tricky because, as yet, there are no bow and arrow sets for G9, as far as I know. I think anything made for G8/8.1 should be easiest to pose, since the starting poses aren't all that different, but you'll still need to parent the bow to the correct hand.
    It also turns out that the Archer Khan poses are NOT hierarchical poses -- you don't need to parent G9 to the horse, or vice versa, just to make the poses work. You pose the horse and rider separately, and then you can parent them together to make movement easier, if you so choose.
  • Thanks. I was only interested to know if i need to buy this special outfit + bow or i can use the bows i already own.
    edited March 2023
    No you don't need to buy elf ranger product unless you really like it. All the bows/arrows you have could be use for Khan.
    After loading the props, just tweak the bow/arrow and hand poses, or use this great script: https://www.daz3d.com/genesis-3-and-8-to-9-pose-converter to convert hand poses on the fly. It supports H.Poses as well.
    Post edited by crosswind on
