DaztoBlender - Will not find in Blender 3.5
aml8g
I have read through countless threads and am having similar issues on the Blender side of things. I am able to get DTB to work on the Daz side (however, the location for the bridge is no longer where they say it is in all of the How-To's). For Blender, I have v 3.5. I don't know if things have changed, but I am not able to find DTB as an available add on to enable, nor find where I can install it. I have follwed the Edit/Preferences/AddOn advice but it doesn't show up. I have tried searching for the Roaming/Blender Foundation path, that also does not show up. I even tried zipping the DTB.dll file and loading it from the desktop. Nothing. Help would greatly be appreciated.
I'm having the same problem! please can someone explain the solution. I'm not entirly sure where the install file is. Even if i follow the path for the addon after making the App folder visible (it was hidden) there seems to be no install file. Please help
SOLVED: Follow this link https://github.com/daz3d/DazToBlender
For 3.5 you have to select the 3.5 folder - THEN select the "scripts" folder
you'll get the success window appear and it'll come up in the blender addon properities window. I didnt select the script folder - I just selected 3.5 folder.
