LAMH2 + Render Queue?
Quick Question:
Is AM's Look At My Hair 2 Iray Catalyzer fundamentally incompatible with ManFriday's Render Queue since LAMH2 has a separate render button? Unless I am missing something on one or more plugin, it seems so.
It's not a huge deal. I'll just have to keep that in mind if I want LAMH2 fur in any overnight renders.
In case you don't already know, the Catalyzer plugin does not render LAMH hair; it specifically renders CATALYZER hair, which is LAMH hair that AM has done some magicks that only he knows to. Many, if not most AM animals in the back catalog have been updated with Catalyzer presets, but you can't create your own LAMH or import someone else's and render that with Catalyzer.
For clarity, these are the products I was inquiring about the use of together:
https://www.daz3d.com/lamh-2-iray-catalyzer
https://www.daz3d.com/render-queue-3
Yes, I know the general difference between LAMH and LAMH2. Thanks for taking the time to respond anyway though.
edit: removed rambling
My guess would be the same as yours, Render queue most likely uses the regular "render" function and since Catalyzer needs a specific one it wouldn't work.
@Leana
Thanks for your input!
Fortunately only a few animals I've gotten seem to need it. I'll have to consider that with some of the decent sales for the older animals though... Looks like from the wild boar and newer it's no longer mentioned in the description as a requirement. Once I someday get the wooly mammoth and brown bear, I'll have to remember to get the dForce hair add-ons too.
